subtractor in quartus
jjxichn
Hello All, I am new to Altera and I am using Agilex to do some interesting stuff. Does any one know whether Quartus Prime 20.4 have ip core to do subtraction with embedded pipelines? I only see Multiply Adder Intel FPGA IP core inside it. What is the best way to do subtraction? Shall I write it in verilog explictly?
FvM
you can use Fixed Point Functions IP, Parrallel Add. Substraction is generated by giving a minus sign to one input parameter.
It has all options to set different pipeline levels and estimates speed.
FvM
did you notice the "+/-" symbol in DSP block schematic? Fixed and float IP perform both add and substract.
jjxichn
That +/- is only for DSP. But I prefer to use ALMs. So I am curious if we can use any IPs to do substraction using ALMs as a pipelined fashion?
FvM
ShengN_Intel
Do you have any further update or concern?
Sheng
