synthesis error 10818
while working with OpenCores SD card controller ( http://opencores.org/project,sdcard_mass_storage_controller
I got error 10818 while trying to synthesize this for Cyclone IV (DE2-115).
The issue boils down to this not synthesizable construct:
module sd_bd ( input clk, input rst, input ena, output reg result ); always @(posedge clk, posedge rst ) begin result <=0; if (rst) result <=0; else if (ena) result <= 1; end endmodule
gives this error message when trying to synthesize it for Quartus 12.1 Build 177:
Critical Warning (10237): Verilog HDL warning at sd_bd.v(10): can't infer register for assignment in edge-triggered always construct because the clock isn't obvious. Generated combinational logic instead Error (10818): Can't infer register for "result" at sd_bd.v(13) because it does not hold its value outside the clock edge File: /commonroot/home/vleo/000_JOB/EISU_OR1200/sdc_test_on_DE2_115/vhdl/sd_controller/sd_bd.v Line: 13
What is described there - seems like a D-trigger, i.e. the ena input is feteched on the clk edge, then held till next clock.
This is certainly not a good way to code what's intended, but this construct is used over and over in sdc_controller project. i wonder what is the workaround, i.e. minimal patch that will allow this to function
Actual code contains other signals on input and output, but the root cause of Quartus error is this ill-shaped D-trigger.
I'm attaching ModelSim archive that shows that this code simulates as expected and Quartus project, that gives error 10818
p.s. I first thought that this illustrates Verilog language deficiency - none of this should happen in VHDL. But unfortunately I got the very same error with VHDL version of the example as well.
In Verilog though, it works, when rst is removed from sensitivity list. So - Verilog seems to win here :)
try this:
begin
//result <=0;
if (rst)
result <=0;
else if (ena)
result <= 1;
else
result <= 0;
end
Great! It works with assignment moved to the else clause - builds in Quartus - and Modelsim shows the same result.
Thank you so much. I'm not good with Verilog+Quartus, this is valuable lesson.
V.L.
Here is an update - although this workaround worked well for the pruned test case, it also works for the "real" code:
always @(posedge clk or posedge rst ) begin new_bw <=0; if (rst) begin m_wr_pnt<=0; write_cnt<=0; new_bw <=0; end else if (we_m) begin if (free_bd >0) begin write_cnt <=~ write_cnt; m_wr_pnt<=m_wr_pnt+1; if (!write_cnt) begin //First write indicate source buffer addr bd_mem<=dat_in_m; end else begin //Second write indicate SD card block addr bd_mem<=dat_in_m; new_bw <=1; end end end end
but the issue now is - moving new_bw to an 'else' clause requires putting it there several times. It's far from mechanical patch. The pattern of
always ... begin xyz<=0; if ... if .. if .. then xyz <=1 ... end
is rather frequent in the sdc_controller code.
So, although this is a workaround, the resulting code is difficult to understand and VERY prone to errors - if you miss one branch, you'll get a register that holds value longer then 1 clock cycle, which is not what is intended.
I still wonder if there is option or way to make Quartus understand this rather simple preposition - a default value on the signal in the always block.
So, what about simply removing 'rst' from the always sensitivity list? This is not quite the same function, but if reset is simply a reset there, not cigar pretending to be a reset :-) it may work.
is this below any good?
always @(posedge clk, posedge rst ) begin //result <=0; if (rst) result <=0; else if (~ena) result <= 0; else result <= 1; end
This IS good, but in real code, there are far more branches and you'll end up with many 'else result <= 0'.
When it's not just one 'result' signal, but say 5 signals, it becomes a real mess.
For now, I'm removing 'posedge rst' - and hope that sync. reset vs. async. will not matter. At least it builds now, we'll see if the whole design works with that.
You can use something like
always @ (posedge clk, posedge rst) begin if (rst) begin // Reset code; compile time only constants. xyz <= 0; else if (enable) begin // Synchronous code xyz <= 0; if (somecondition) xyz <= 1; else if (someother condition) xyz <= 2; end end
The problem in your first code snippet was that you have an action outside the first "if/else" block, so the behavior wasn't clear to the tool.
--- Quote Start ---
--- Quote End ---
I believe most of the FPGA synthesis tools have a problem understanding the structure of a MUX and a FF when the "always @(.... " structure has a default assignment outside the if/else-if/else structure. When I have to add a default assignment, I generally do it as follows.
reg result_comb; reg result; always @(*) begin result_combo = 0; if(cond1) result_combo = 1; else if (cond2) result_combo = 0; end always @(posedge clk, posedge rst) begin if(rst) result <= 0; else result <= result_combo end
This may not satisfy the "minimal patch" requirement, but it works
