17267 Discussions
system_integrator : core dumped
I'm currently following the beginner's guide for intel FPGA on linux host (https://www.youtube.com/watch?v=npeuaj-mfvy&t=2s) but I'm stuck during the compilation process of the device with a corre dumped.
The command is :
aoc device/vector_add.cl -o bin/vector_add.aocx --report --board c5soc_sharedonly
Here's the problem :
http://www.alteraforum.com/forum/attachment.php?attachmentid=13170&stc=1
The log file shows the same thing.
Have you got any clue on how to solve this problem ?
Please post the following info:
1- Output of "aoc --version"
2- Version of vector_add example you are using
3- Operating System and amount of memory installed on the machine on which you are compiling the kernel
1)
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler Version 16.1.0 Build 196 Copyright (C) 2016 Intel Corporation
2)
exm_opencl_vector_add_arm32_linux.tgz V16.1
3)
Ubuntu 16.04.1 LTS with 30Go and 7.5 Go free
Please install update v16.1.1 for both Quartus and AOC and see if it fixes the problem; v16.1.0 has issues with OpenCL compilation.
unfortunatly this do not solve the issue ...
Can you post the "quartus_sh_compile.log" file? Also retry "aoc --version" and make sure the update has been installed correctly.
Here is the aoc version
Version 16.1.1 Build 200
and the file is attached
Actually the kernel log is not very helpful in debugging such issues, that is why I asked for the "quartus_sh_compile.log" file. Though you might not have that log at all since it seems your compilation is crashing in the OpenCL to HDL conversion phase. If you have the quartus_sh_compile.log file, please post that, if not, your problem might be a permission issue. Try switching to the root user and running everything as root.
