17256 Discussions
_tb has no architecture (error in modelsim(of altera)(14.0)), plz help
simple program and its testbench(copy from book of volnei a. pedroni 2 e)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY mydesign_tb IS
END ENTITY;
ARCHITECTURE testbench OF mydesign_tb IS
---DUT declaration:------
COMPONENT mydesign IS
PORT (clk, rst, din: IN STD_LOGIC;
dout: OUT STD_LOGIC);
END COMPONENT;
----signal declarations:-----
SIGNAL clk: STD_LOGIC := '0';
SIGNAL rst: STD_LOGIC := '1';
SIGNAL din: STD_LOGIC := '0';
BEGIN
---DUT instantiation:-----
dut: mydesign PORT MAP (clk, rst, din, dout);
----stimuli generation:-----
clk <= NOT clk AFTER 40ns;
rst <= '0' AFTER 80ns;
din <= '1' AFTER 160ns, '0' AFTER
240ns, '1' AFTER 32ns;
END ARCHITECTURE;
LIBRARY ieee;
ENTITY mydesign IS
END ENTITY;
ARCHITECTURE mydesign OF mydesign IS
BEGIN
PROCESS (clk, rst)
VARIABLE q: STD_LOGIC_VECTOR(0 TO 3);
BEGIN
IF (rst='1') THEN
q := (OTHERS => '0');
ELSIF (clk'EVENT AND clk='1') THEN
q := din & q(0 TO 2);
END IF;
dout <= q(3);
END PROCESS;
END ARCHITECTURE;
but when I try to compile(both, error on tb-"unknown identifier dout") and simulate tb, error about no architecture of tb on my altera modelsim 14.0 on linux-ubuntu 14.04. plz help, eric
you need to declare dout in the testbench declaration area like din...
thanks your reply/suggestion, I follow / tried, the result is : although it compile and simulate(tb), but no wave form and its message stated: no data(for all variables, clk, rst, din, dout), so plz help again or any other advanced programer's advice. thanks a lot in advance. (according to that book, "circuit design and simulation with VHDL 2nd edition, that example is worked on MentorGraphic's modelsim, not altera's; so
if anyone have successful run's altera modelsim program(both design file and its testbench file in vhdl(.vhd) form of short/simple programs, plz point/refer a link or post on this thread. thanks)
--- Quote Start ---
--- Quote End ---
after simulation you will need to add these objects (clk,reset,din,dout) to ayour waveform. then run the waveform.
