17255 Discussions
tcl script for design partition
Can I write a tcl script to create design partitions and a tcl script for logic lock.
My code is written in verilog.
Use the GUI to create a LogicLock region, and then adjust things until you are happy with them. Then use "Project->Generate Tcl File for Project" to create a Tcl script for your project. That Tcl script will contain a lot of assignments that start with LL_ (logic lock).
That should be enough to get you started.
Cheers,
Dave
