I have generated a collection thus:
set clkcoll [get_clocks *] foreach_in_collection clk $clkcoll { puts [ get_object_name $clk ] } How do I translate the collection iterator into a name string? Synopsys has the "get_object_name" function to return the object name as a string. This does not work in Time Quest. What is the Time Quest method? Solution found: get_object_info $item -name set clkcoll [get_clocks *] foreach_in_collection item $clkcoll { set clk [get_object_info $item -name] puts $clk }Link Copied
