17254 Discussions
unconnect port warning.
when a instance port is not connected,
Quartus report a connectivty issue.
how to avoid this.
In VDHL use 'open'
E.g
a : b port map (
clk => clk ,
thispin => open,
thank you. but i like use Verilog. Do you know how write Verilog code like this?
Sorry, I wouldn't touch Verilog with a bargepole i.e. I don't know much about Verilog.
Let's hope the Verilog experts will step in.
In VHDL and verilog, any out ports left out are left open by default. But you must connect and input port to something if it has no default value, even if it's a constant.
WHy not post the actual error?
