17249 Discussions
uploading the program to the FPGA
Alexandre_02
Hi. When compiling a project in Quartus Prime Lite Edition 13.1, a .pof file is not created, only .sof is created. Because of this, I cannot load the program into the Cyclone V GX Starter Kit FPGA. Tell me how to compile the project so that the file with the extension was .pof created?
Alexandre_02
I tried to convert the .sof file to a .pof file and add it to the Programmer to upload to the FPGA. The following message appeared:
Cannot and target device EPCQ256 to device chain when in current programming mode.
Alexandre_02
I have read the difference between these files. Cyclone V GX does not have a ROM. Now I understand the differences. But the following problem arose with removing the firmware from the FPGA memory. Can you tell me how to correctly remove the firmware from memory? This is the only remaining question.
NurAiman_M_Intel
NurAiman_M_Intel
Any update for this case?
Aiman
NurAiman_M_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
