use an entity in process
I write four VHDL file
1) 1 bit full adder
2) 8 bit full adder
3) 1 bit flip flop
4) accumulator
1 and 2 and 3 is correct and I tested those , but I have a really big problem in accumulator!
this is picture of accumulator that I want build by 1,2 and 3 :
http://www.alteraforum.com/forum/attachment.php?attachmentid=10883&stc=1
I'm new in VHTL . I try to write a accumulator but it's full of error and logical problems. you can see for above code blow :
1) 1 bit full adder
Library ieee;
Use ieee.std_logic_1164.all;
Entity fullAdder is
port(
Cin : in std_logic;
x : in std_logic;
y : in std_logic;
s : out std_logic;
Cout : out std_logic
end fullAdder;
Architecture fullAdder_logic of fullAdder is
begin
s <= x xor y xor Cin;
Cout <= (x and y) or (x and Cin) or (y and Cin);
end Architecture;
2) eight bit adder
Library ieee;
Use work.all;
Entity eightBitAdder is
port(
Cin : in std_logic;
x : in std_logic_vector(7 downto 0);
y : in std_logic_vector(7 downto 0);
s : out std_logic_vector(7 downto 0);
Cout: out std_logic
end eightBitAdder;
Architecture eightBitAdder_logic of eightBitAdder is
component fullAdder
port(
Cin,x,y : in std_logic;
s,Cout : out std_logic
end component;
signal carry : std_logic_vector(8 downto 0);
begin
carry(0) <= Cin;
gen_add: for i in 0 to 7 generate
lebel_fulladd: fullAdder port map (carry(i), x(i), y(i), s(i), carry(i + 1));
end generate gen_add;
Cout <= carry(8);
end Architecture;
3 ) 1 bit d_ff
library ieee;
use ieee.std_logic_1164.all;
entity D_ff is
port (
D: in std_logic;
CLK: in std_logic;
RST: in std_logic;
Q: out std_logic
end D_ff;
architecture D_ff_logic of D_ff is
signal ff_state: std_logic; -- This will hold flip flop state
begin
process(CLK)
begin
if rising_edge(CLK) then
if RST='1' then
ff_state <= '0'; -- Reset, change state to 0.
else
ff_state <= D; -- 'clock' in input.
end if;
end if;
end process;
-- Output current flip flop state
Q <= ff_state;
end architecture;
4) accumulator !!
library ieee;
use ieee.numeric_std.all;
entity accumulator is
port (
Input: in std_logic_vector(7 downto 0);
CLK: in std_logic;
Output: out std_logic_vector(7 downto 0)
end entity accumulator;
architecture accumulator_logic of accumulator is
component D_ff is
port (
D: in std_logic;
CLK: in std_logic;
RST: in std_logic;
Q: out std_logic
end component;
component eightBitAdder is
port(
Cin : in std_logic;
Cout: out std_logic
end component;
signal DFF_AC: std_logic_vector(7 downto 0);
signal overFlow: std_logic;
signal cout: std_logic;
begin
DFF_Ac0: D_ff port map ( '0', CLK, '1', DFF_AC(0));
DFF_Ac1: D_ff port map ( '0', CLK, '1', DFF_AC(1));
DFF_Ac2: D_ff port map ( '0', CLK, '1', DFF_AC(2));
DFF_Ac3: D_ff port map ( '0', CLK, '1', DFF_AC(3));
DFF_Ac4: D_ff port map ( '0', CLK, '1', DFF_AC(4));
DFF_Ac5: D_ff port map ( '0', CLK, '1', DFF_AC(5));
DFF_Ac6: D_ff port map ( '0', CLK, '1', DFF_AC(6));
DFF_Ac7: D_ff port map ( '0', CLK, '1', DFF_AC(7));
process(CLK)
begin
if overFlow = '0' then
DFF0: D_ff port map ( DFF_AC(0), CLK, '0', DFF_AC(0));
DFF1: D_ff port map ( DFF_AC(1), CLK, '0', DFF_AC(1));
DFF2: D_ff port map ( DFF_AC(2), CLK, '0', DFF_AC(2));
DFF3: D_ff port map ( DFF_AC(3), CLK, '0', DFF_AC(3));
DFF4: D_ff port map ( DFF_AC(4), CLK, '0', DFF_AC(4));
DFF5: D_ff port map ( DFF_AC(5), CLK, '0', DFF_AC(5));
DFF6: D_ff port map ( DFF_AC(6), CLK, '0', DFF_AC(6));
DFF7: D_ff port map ( DFF_AC(7), CLK, '0', DFF_AC(7));
adder: eightBitAdder( '0', std_logic_vector(Input), std_logic_vector(DFF_AC), std_logic_vector(DFF_AC),cout);
overFlow <= cout xor DFF_AC(7);
end if;
end if;
end process;
-- Assign output
--DOUT <= our_ffs;
end architecture;
i can't fix this with out help!
You cant instatiate components inside a process - thats like asking the code to put a new chip on a circuit board on the rising edge of every clock - not very realistic.
THink of components like microchips - and instantiating them is like connecting one on a circuit board. A process is describing logic, not connectivity.
So, put the instantiations outside of the process.
My problem is => I don't know how put 1,2 and 3 together to make accumulator!
Usually an accumulator is just an adder where one of the inputs is a registered version of it's own output.
I change accumulator VHDL code , but when I make it's wave form it litte wrong!
(I add few line to other section too!)
there are codes:
1) 1 bit full adder
Library ieee;
Entity fullAdder is
port(
CLK : in std_logic;
Cin : in std_logic;
x : in std_logic;
y : in std_logic;
s : out std_logic;
end fullAdder;
begin
process(CLK)
begin
end if;
end process;
end Architecture;
2) 8 bit adder
Library ieee;
Use work.all;
port(
CLK : in std_logic;
Cin : in std_logic;
Cout: out std_logic
end eightBitAdder;
component fullAdder
port(
CLK :in std_logic;
end component;
begin
carry(0) <= Cin;
lebel_fulladd: fullAdder port map (CLK, carry(i), x(i), y(i), s(i), carry(i + 1));
Cout <= carry(8);
end Architecture;
3 ) 1 bit flip flop
library ieee;
entity D_ff is
port (
D: in std_logic;
CLK: in std_logic;
RST: in std_logic;
Q: out std_logic
end D_ff;
begin
process(CLK)
begin
if RST='1' then
else
end if;
end if;
end process;
Q <= ff_state;
end architecture;
4 ) accumulator
library ieee;
port (
CLK: in std_logic;
component D_ff is
port (
D: in std_logic;
CLK: in std_logic;
RST: in std_logic;
Q: out std_logic
end component;
port(
CLK : in std_logic;
Cin : in std_logic;
Cout: out std_logic
end component;
signal ALU_out: std_logic_vector(7 downto 0);
begin
--DFF_Ac0: D_ff port map ( '0', CLK, '1', DFF_AC(0));
--DFF_Ac1: D_ff port map ( '0', CLK, '1', DFF_AC(1));
--DFF_Ac2: D_ff port map ( '0', CLK, '1', DFF_AC(2));
--DFF_Ac3: D_ff port map ( '0', CLK, '1', DFF_AC(3));
--DFF_Ac4: D_ff port map ( '0', CLK, '1', DFF_AC(4));
--DFF_Ac5: D_ff port map ( '0', CLK, '1', DFF_AC(5));
--DFF_Ac6: D_ff port map ( '0', CLK, '1', DFF_AC(6));
--DFF_Ac7: D_ff port map ( '0', CLK, '1', DFF_AC(7));
adder: eightBitAdder port map(CLK, '0', std_logic_vector(Input), std_logic_vector(DFF_AC), ALU_out,cout);
DFF0: D_ff port map ( ALU_out(0), CLK, '0', DFF_AC(0));
DFF1: D_ff port map ( ALU_out(1), CLK, '0', DFF_AC(1));
DFF2: D_ff port map ( ALU_out(2), CLK, '0', DFF_AC(2));
DFF3: D_ff port map ( ALU_out(3), CLK, '0', DFF_AC(3));
DFF4: D_ff port map ( ALU_out(4), CLK, '0', DFF_AC(4));
DFF5: D_ff port map ( ALU_out(5), CLK, '0', DFF_AC(5));
DFF6: D_ff port map ( ALU_out(6), CLK, '0', DFF_AC(6));
DFF7: D_ff port map ( ALU_out(7), CLK, '0', DFF_AC(7));
process(CLK)
begin
Output <= DFF_AC;
else
end if;
end process;
end architecture;
if give input(00000001) to accumulator and draw wave form it work's but a little wrong!
Your post doesnt make a lot of sense.
Have you got a testbench? can you debug this yourself?
above code compile correctly , But when I simulate it functionality , it's diagram have a little bit wrong!
I review code many time but I did not find where I do mistake .
I take a picture from ccumulator.vhd wave form :
http://s6.picofile.com/file/8200419576/pic5.png
It is right 60% but I don't know where I do mistake because I'm very very
I take a picture from accumulator wave form :
It is right 60% but I don't know where I do mistake because I'm very very new In VHDL .
--- Quote Start ---
--- Quote End ---
I take this picture from accumulator wave form :
It is right 60% but I don't know where I do mistake because I'm very very beginner.
