Hi All,
What does# mean within the context of verilog module declarations ? Thanks, mark ================ module zl_fifo_2# ( parameter Width = 0 ) ( input clk, input rst_n, // input data_in_req, output data_in_ack, input [Width-1:0] data_in, // output data_out_req, input data_out_ack, output [Width-1:0] data_out );Link Copied
# means generic definitions or generic map. Its a region where you can define a load of parameters that can be modified when the module is instantiated.
