user_defined ip confused
hi,
i am confused that i have created a ip core in sopc, the ip core is just a interface module ,not assign a hdl file, when i first edit the ip core, it's ok,after refresh system, i see it again,but when i want to edit again by clicking the right mouse key ,there is no "Edit" option.
Have you a solution ?
When you make a new component, SOPC builder creates a *_hw.tcl file that contains all the parameters you set. Open this file with a text editor and look for a line that looks like this:
set_module_property EDITABLE falseand change it to:set_module_property EDITABLE true
Save the file, refresh the SOPC system and you should be able to edit your component.
