17268 Discussions
uvm_config_db fails to get interface UVM QuestaSim
AlexBeasley
Hi there
I am trying to get a simulation working in QuestaSim - Intel FPGA Edition using UVM.
Below is the design with all the UVM class extensions
`timescale 1ns/1ps
`include "uvm_macros.svh"
`define LENGTH 4
	import uvm_pkg::*;
	class Item extends uvm_sequence_item;
		`uvm_object_utils(Item)
		rand bit in;
		bit 	 out;
		virtual function string convert2str();
			return $sformatf("in=%0d, out=%0d", in, out);
		endfunction
		function new(string name = "Item");
			super.new(name);
		endfunction
		constraint c1 {in dist {0:/20, 1:/80}; }
	endclass
	class gen_item_seq extends uvm_sequence;
		`uvm_object_utils(gen_item_seq)
		function new(string name="gen_item_seq");
			super.new(name);
		endfunction
		rand int num; 		// config total number of items to be sent
		constraint c1 { soft num inside {[10:50]}; }
		virtual task body ();
			for(int i = 0; i < num; i++) begin
				Item m_item = Item::type_id::create("m_item");
				start_item(m_item);
				m_item.randomize();
				`uvm_info("SEQ", $sformatf("Generate new item: %s", m_item.convert2str()), UVM_HIGH)
				finish_item(m_item);
			end
			`uvm_info("SEQ", $sformatf("Done generation of %0d items", num), UVM_LOW)
		endtask
	endclass
	//The driver is responsible for driving transactions to the DUT
	// All it does it to get a transaction from the mailbox if it is
	// available and drive it out into the DUT interface
	class driver extends uvm_driver #(Item);
		`uvm_component_utils(driver)
		function new(string name = "driver", uvm_component parent=null);
			super.new(name, parent);
		endfunction
		virtual des_if vif;
		virtual function void build_phase(uvm_phase phase);
			super.build_phase(phase);
			if(!uvm_config_db#(virtual des_if)::get(this, "", "des_if", vif))
				`uvm_fatal("DRV", "Could not get vif")
		endfunction
		virtual task run_phase(uvm_phase phase);
			super.run_phase(phase);
			forever begin
				Item m_item;
				`uvm_info("DRV", $sformatf("Wait for item from sequencer"), UVM_HIGH)
				seq_item_port.get_next_item(m_item);
				drive_item(m_item);
				seq_item_port.item_done();
			end
		endtask
		virtual task drive_item(Item m_item);
			@(vif.cb);
			  vif.cb.in <= m_item.in;
		endtask
	endclass
	// The monitor has a virtual interface handl with which
	// it can monitor the events happening on the interface
	// It sees new transcations then captures information
	// into a packet and sends it to the scoreboard
	// using another mailbox
	class monitor extends uvm_monitor;
		`uvm_component_utils(monitor)
		function new(string name="monitor", uvm_component parent=null);
		endfunction
		uvm_analysis_port #(Item) mon_analysis_port;
		virtual des_if vif;
			if(!uvm_config_db#(virtual des_if)::get(this, "", "des_vif", vif))
				`uvm_fatal("MON", "Could not get vif")
			mon_analysis_port = new ("mon_analysis_port", this);
		endfunction
			//This task monitors the interface for a complete
			// transaction and writes into analysis port when complete
			forever begin
				@(vif.cb);
				if(vif.rstn) begin
					Item item = Item::type_id::create("item");
					item.in = vif.in;
					item.out = vif.cb.out;
					mon_analysis_port.write(item);
					`uvm_info("MON", $sformatf("Saw item %s", item.convert2str()), UVM_HIGH)
				end
			end
		endtask
	endclass
	// The scoreboard is reponsible for checking design functionality and
	// should track input and try to match the pattern and ensure that
	// the design has found the pattern as well. The scoreboard should
	// flag an error if the design didn't find the pattern and ensure
	// that "out" remains zero, and if the design found the pattern,
	// "out" is set to the correct value
	class scoreboard extends uvm_scoreboard;
		`uvm_component_utils(scoreboard)
		function new(string name="scoreboard", uvm_component parent=null);
		endfunction
		bit [`LENGTH-1:0] ref_pattern;
		bit [`LENGTH-1:0] act_pattern;
		bit				  exp_out;
		uvm_analysis_imp #(Item, scoreboard) m_analysis_imp;
			m_analysis_imp = new("m_analysis_imp", this);
			if(!uvm_config_db#(bit[`LENGTH-1:0])::get(this, "*", "ref_pattern", ref_pattern))
				`uvm_fatal("SCBD", "Did not get ref_pattern !")
		endfunction
		virtual function write(Item item);
			act_pattern = act_pattern << 1 | item.in;
			`uvm_info("SCBD", $sformatf("in=%0d out=%0d ref=0b%0b act=0b%0b", item.in, item.out, ref_pattern, act_pattern), UVM_LOW)
			// Always check that expected out value is the actual obseved value,
			// Since it takes 1 clock for out to be updated after pattn match,
			//do the check first then update exp_out value
			if(item.out != exp_out) begin
				`uvm_error("SCBD", $sformatf("ERROR ! out=%0d exp=%0d", item.out, exp_out))
			end else begin
				`uvm_info("SCBD", $sformatf("Pass ! out=%0d exp=%0d", item.out, exp_out), UVM_HIGH)
			end
			// If current index has reached the full pattern, then set exp_out to be 1
			// which will be checked in the next clock. If pattern is not complete, keep
			// exp_out to zero
			if(!(ref_pattern ^ act_pattern)) begin
				`uvm_info("SCBD", $sformatf("Pattern found to match, next one should be 1!"), UVM_LOW)
				exp_out = 1;
			end else begin
				exp_out = 0;
			end
		endfunction
	endclass
	// Create an intermediate container called "agent" to hold
	// driver, monitor and sequencer
	class agent extends uvm_agent;
		`uvm_component_utils(agent)
		function new(string name="agent", uvm_component parent=null);
		endfunction
		driver 		d0; 			//Driver handle
		monitor 	m0;				//Monitor handle
		uvm_sequencer #(Item) s0;	//Sequence Handle
			s0 = uvm_sequencer#(Item)::type_id::create("s0", this);
			d0 = driver::type_id::create("d0", this);
			m0 = monitor::type_id::create("m0", this);
		endfunction
		virtual function void connect_phase(uvm_phase phase);
			super.connect_phase(phase);
			d0.seq_item_port.connect(s0.seq_item_export);
		endfunction
	endclass
	// The environment is a contain objet simply to hold
	// all verification components together. This environment can
	// then be reused later and all components in it would be
	// automatically connected and available for use
	class env extends uvm_env;
		`uvm_component_utils(env);
		function new(string name="env", uvm_component parent=null);
		endfunction
		agent 		a0; 	//agent handle
		scoreboard	sb0;	//scoreboard handle
			a0 = agent::type_id::create("a0", this);
			sb0 = scoreboard::type_id::create("sb0", this);
		endfunction
			a0.m0.mon_analysis_port.connect(sb0.m_analysis_imp);
		endfunction
	endclass
	// Test class instantiates the environment and starts it.
	class base_test extends uvm_test;
		`uvm_component_utils(base_test)
		function new(string name="base_test", uvm_component parent=null);
		endfunction
		env				e0;
		bit[`LENGTH-1:0] pattern = 4'b1011;
		gen_item_seq	seq;
		virtual des_if vif;
			// create the environment
			e0 = env::type_id::create("e0", this);
			// Get virtual IF handle from the top level and pass it to everything
			// in the env level
				`uvm_fatal("TEST", "Did not get vif")
			uvm_config_db#(virtual des_if)::set(this, "e0.a0.*", "des_if", vif);
			// Setp pattern queue and place into config db
			uvm_config_db#(bit[`LENGTH-1:0])::set(this, "*", "ref_pattern", pattern);
			// Create sequence and randomise it
			seq = gen_item_seq::type_id::create("seq");
			seq.randomize();
		endfunction
			phase.raise_objection(this);
			apply_reset();
			seq.start(e0.a0.s0);
			#200;
			phase.drop_objection(this);
		endtask
		virtual task apply_reset();
			vif.rstn <= 0;
			vif.in 	 <= 0;
			repeat(5) @ (posedge vif.clk);
			vif.rstn <= 1;
			repeat(10) @ (posedge vif.clk);
		endtask
	endclass
	class test_1011 extends base_test;
		`uvm_component_utils(test_1011)
		function new (string name="test_1011", uvm_component parent=null);
		endfunction
			pattern = 4'b1011;
			seq.randomize() with { num inside {[300:500]}; };
		endfunction
	endclass
	// This interface allows verification components to access DUT signals
	// using a virtual interface handle
	interface des_if (input bit clk);
		logic rstn;
		logic in;
		logic out;
		clocking cb @ (posedge clk);
			default input #1step output #3ns;
			input out;
			output in;
		endclocking
	endinterface
module tb();
	reg clk;
	always #10 clk =~ clk;
	des_if _if(clk);
	det_1011 u0 (
		.clk(clk),
		.rstn(_if.rstn),
		.in(_if.in),
		.out(_if.out)
	initial begin
		clk <= 0;
		uvm_config_db#(virtual des_if)::set(null, "uvm_test_top", "des_vif", _if);
		run_test("test_1011");
	end
endmodule : tb
// Design v1.0
module det_1011 (input clk,
				 input rstn,
				 input in,
				 input out);
	parameter IDLE  = 0,
			  S1 	= 1,
			  S10   = 2,
			  S101  = 3,
			  S1011 = 4;
	reg [2:0] cur_state, next_state;
	assign out = cur_state == S1011 ? 1 : 0;
	always @ (posedge clk)
	begin
		if(!rstn)
			cur_state <= IDLE;
		else
			cur_state <= next_state;
	end
	always @ (cur_state or in)
	begin
		case(cur_state)
			IDLE: begin
				if (in) next_state = S1;
				else next_state = IDLE;
			end
			S1 : begin
				if (in) next_state = IDLE;
				else 	next_state = S10;
			end
			S10 : begin
				if (in) next_state  = S101;
			end
			S101: begin
				if (in) next_state = S1011;
			end
			S1011 : begin
				next_state = IDLE;
			end
		endcase
	end
endmodule
Which I then attempt to run in QuestaSim using the following commands
(The example file above has been saved as "tb.sv")
vlib work
vmap work work
set UVM_HOME C:/Data/uvm-1.2/
vlog +acc -work work +incdir+$UVM_HOME C:/Data/uvm_example/tb.sv
vsim -t fs -vopt -voptargs="+acc +cover" +incdir+$UVM_HOME work.tb
However I am getting a fatal error when the test routine checks for the connected interface:
# UVM_FATAL C:/Data/uvm_example/tb.sv(274) @ 0: uvm_test_top [TEST] Did not get vif
I cannot spot the error. Can anyone see it?
I also am not sure whether QuestaSim will support using UVM like this?
Alex
AlexBeasley
The problem has been spotted.
Note: there is a typo in some of the
uvm_config_db#()::get()/set()
lines, where I have mixed up "des_vif" and "des_if" for the handle!
Totally didn't spot it!
RichardTanSY_Altera
I am using Questa Intel FPGA Edition-64 2022.1 Revision: 2022.01
I run using the tb.sv provided, along with the command, and does not see any fatal error.
Richard Tan
RichardTanSY_Altera
The fatal error is generated from the tb.sv itself. You might need to check line 274.
AlexBeasley
RichardTanSY_Altera
Great to hear that! With the issue resolved, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
