17241 Discussions
verilog code for distributed arithemetic.
hello,
I am using multiplier in adaptive filter implementation.Instead of this,i have to use distributed arithmetic.It has to be done tomorrow.
so can anyone please help me to write the code as soon as possible.:(:(
regards,
sathia
--- Quote Start ---
hello,
regards,
sathia
--- Quote End ---
You are a bit early? but this may help:
http://www.dsprelated.com/showarticle/555.php
i know the concept of DA and i can do the mathematical verification.i don't know "how to write the code".
so can you send me the code in verilog.
--- Quote Start ---
--- Quote End ---
It says verilog code for the design is available for download.
Thank you sir,i couldn't understand the coding.can you explain the code in detail?because it contains only code.
I need an explanation for link:verilog source code
hiii,
i am having verilog code for distributed arithmetic.but i can't able to compile the code.
so please ensure that,is that code for DA and correct the errors.
regards,
sathia
please send me the code of distributed arithmetic for fir adaptive filter as soon as possible.
