Hi all,
yesterday I got a problem while adapting an foreign project in verilog for my testboard. The code includes a lot of lines where a kind of default value has been defined and quartus always throws an error 10818 saying that it is not able to synthesise this code. The code always follows the following pattern:
always @(posedge ...)
aout <= 0;
if (...) begin
if (...) begin
if (...) begin
aout <= 1;
end
else begin
end
end
end
My experience is very limited, but I think that this code is not following the code style guidelines, although modelsim and an actel compiler seem to tolerate this code. It would be a lot of work to assign 'aout' in all "else" cases and I am sure I would miss one. ok, but is there any way to define a kind of 'default' value, for all if-branches, where 'aout' is not assigned that is following the code style guidelines ? thanks for your help. any hints for documentation about this pattern are welcome. cheers, eag1e
This code is badly written.
If you don't have time to rewrite it completely i can give a suggestion. What if you create two procedural blocks? One should generate the "aout" signal in a combinatorial way and hence is not synchronized by the clock. The second one is a simple flip flop that synchronizes the signal. Maybe that in this way the synthesizer has a simplified life.- Mark as New
Thanks nplttr for your suggestion,
probably this will be the best way. The whole structure is difficult to understand because I think it's written far to complicated. It just seemed that I found the real reason for the quartus-error and I have to say, I have hidden the most important part:
always @(posedge wb_rst_i)
aout <= 0;
if (wb_rst_i) begin
if (...) begin
if (...) begin
aout <= 1;
end
else begin
end
end
end
elseif (...) begin
aout <= 1;
end
So I think the main problem quartus has, is that there are both clock edges used due to the 'elseif' in the end. But why the hell, is it synthesisable when I comment out the first 'aout <= 0' ?
The code doesn't look like a double edge triggered (that is however not synthesizable).
You only have the posedge wb_rst_i in the sensitivity list (for a double edge you should have "posedge ... or negedge ..."). Did you try as I said? My idea is: always @(every signal on the right side of the assignments) aout_comb <= 0; if (wb_rst_i) begin if (...) begin if (...) begin aout <= 1; end else begin ... end ... end ... end elseif (...) begin ... aout_comb <= 1; ... end always @(posedge wb_rst_i) begin aout <= aout_comb; end- Mark as New
hmm, bad - you're right.
Time to go for a walk - I seem to have tomatoes on my eyes. No sry, I didn't try it yet, because it's not only aout, there are 7 registers in a really huge if-else-tree, that cannot be infered. I'm just on my way to split it like you said - its a lot of work - but nobody told me that a wishbone-controller would be easy. thanks :)- Mark as New
Hello again,
quartus is going to drive me crazy. at first nplttr, no - it didn't work. So I tried to write the controller for my own memory bus first and earned the same: --- Quote Start --- Error (10818): Can't infer register for "fb_data[0]" at SD_controller_FlexBus.vhd(26) because it does not hold its value outside the clock edge --- Quote End --- forLIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY SD_CONTROLLER_FB IS
GENERIC( BUSWIDTH: natural := 8);
PORT
fb_data : inout std_logic_vector(7 downto 0);
fb_addr : in std_logic_vector(19 downto 0);
fb_cs : in std_logic_vector(1 downto 0);
fb_oe : in std_logic;
fb_rw : in std_logic;
fb_ale : in std_logic;
clk : in std_logic;
fb_rx_bd : out std_logic_vector(BUSWIDTH-1 downto 0);
fb_tx_bd : in std_logic_vector(BUSWIDTH-1 downto 0)
END SD_CONTROLLER_FB;
ARCHITECTURE SD_CONTROLLER_FB_architecture OF SD_CONTROLLER_FB IS
BEGIN
PROCESS (fb_ale)
BEGIN
IF (rising_edge(fb_ale)) THEN
fb_data <= "ZZZZZZZZ";
ELSE
fb_data <= "11111111";
END IF;
END PROCESS;
END SD_CONTROLLER_FB_architecture;
WHY ? there are 2 damn constants for now ?! At this stage its so easy that I would be able to solder this circuit. cheers, eag1e
ok,
http www<dot>altera<dot>com/support/examples/vhdl/v_bidir.html does not work - also an Error 10818. The examples seem to be for a PLD. Is it a FPGA-specific problem???- Mark as New
You should stick to the standard process model to be sure it can be synthesized:
process (clock,reset)
begin
if (reset='1') then
-- reset condtions
elsif rising_edge(clock) then
-- clocked actions
end if;
end process;
Don't try to do anything on the falling edge of the clock in the same process.
