17255 Discussions
verilog define in the .qsf or .tcl for quartus?
AEsqu
I use this command in a Synplify project to define for a verilog check code translation:
set_option -hdl_define -set {"WITH_TH"}
This is then picked in verilog:
`ifdef WITH_TH
  code line here will be picked
`endif
endmodule
My question:
How to do it for Quartus?
I'm used to the
set_parameter -name ...
but that is not applicable in this case.
Thanks!
AEsqu
Is this the only way?
Create a new verilog file with this inside:
`define WITH_TH
and add this file in the quartus .qsf
YEan
AEsqu
Hi Ean,
your answer is about creating a vqm file,
which is not the question.
Anyway, I used what I proposed after as a workaround.
YEan
Hi ,
I’m glad that your issue has been resolved. I'll now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
Ean
