verlog code error
Hi,anybody please help me to identify the error in coding.
ThANK YOU
--- Quote Start ---
Error (10137): Verilog HDL Procedural Assignment error at expr.v(15): object "pwm" on left-hand side of assignment must have a variable data type
--- Quote End ---
If you don't manage to learn Verilog syntax from the bottom, you should at least read error messages thoroughly.
An output port that is assigned in a procedural statement must be defined as reg, e.g.
output reg pwm;
or
output pwm; reg pwm;
sorry,
Thankyou....
