what is the problem?
gAcqu
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY add_three_numbers IS
PORT ( clock : IN STD_LOGIC;
A, B, C : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
sum : OUT STD_LOGIC_VECTOR(9 DOWNTO 0));
END add_three_numbers;
ARCHITECTURE Behavior OF add_three_numbers IS
-- Registers
SIGNAL reg_A, reg_B, reg_C : STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL reg_sum : STD_LOGIC_VECTOR(9 DOWNTO 0);
ATTRIBUTE keep : boolean;
ATTRIBUTE keep OF reg_A, reg_B, reg_C, reg_sum : SIGNAL IS true;
BEGIN
PROCESS ( clock )
BEGIN
IF (clock’EVENT AND clock = ‘1’) THEN
reg_A <= A;
reg_B <= B;
reg_C <= C;
reg_sum <= ("00" & reg_A) + ("00" & reg_B) + ("00" & reg_C);
END IF;
END PROCESS;
sum <= reg_sum;
END Behavior;
Error (10500): VHDL syntax error at add_three_numbers.vhd(18) near text ’
Error (10500): VHDL syntax error at add_three_numbers.vhd(18) near text "’"; expecting ")", or ","
Error (10500): VHDL syntax error at add_three_numbers.vhd(18) near text ‘
Error: Quartus II Analysis & Synthesis was unsuccessful. 3 errors, 1 warning
   Error: Peak virtual memory: 303 megabytes
   Error: Processing ended: Fri Apr 03 18:52:58 2020
   Error: Elapsed time: 00:00:07
   Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 5 errors, 1 warning
imarz1
You must have typed invisible ASCII character in the line:
IF(clock'EVENT AND clock = '1') THEN
So, just delete that line completely, and re-write it.
Also, good to add as first line of code: library IEEE;
gAcqu
