wire a_cs_n;
wire b_cs_n; assign a_cs_n = (addr[19:18]==2'b01)? 1'b0 : 1'b1; assign b_cs_n = (addr[19:18]==2'b00 && addr[17:16]==2'b10) ? 1'b0 : 1'b1; assign dout = ({16 {a_cs_n}} | 16'haaaa ) & ({16 {b_cs_n}} | 16'hbbbb) ; With QII 6.1,dout can get 16'haaaa or 16'hbbbb.But with Qii 9.0,dout cannot get 16'haaaa。 We don't change the code.But get the different result. Why? Thank you very much!Link Copied
--- Quote Start --- wire a_cs_n; wire b_cs_n; assign a_cs_n = (addr[19:18]==2'b01)? 1'b0 : 1'b1; assign b_cs_n = (addr[19:18]==2'b00 && addr[17:16]==2'b10) ? 1'b0 : 1'b1; assign dout = ({16 {a_cs_n}} | 16'haaaa ) & ({16 {b_cs_n}} | 16'hbbbb) ; With QII 6.1,dout can get 16'haaaa or 16'hbbbb.But with Qii 9.0,dout cannot get 16'haaaa。 We don't change the code.But get the different result. Why? Thank you very much! --- Quote End --- Hi, I run a test with Quartus II 9.0 (Full version). I looks pretty in my project. I have the project attached. Maybe I made a mistake in the project ? Kind regards GPK
Why don't you write:
always @ (*) begin if (a_cs_n) dout <= 16'haaaa; if (b_cs_n) dout <= 16'hbbbb; end
