17266 Discussions
when I generated PLL ip before, a file name _inst.v was generated, so I can copy the example to my script. but the new one in quartus 17/18, the file seems missing. where can I find the example file?
ZLu001
Vicky1
Hi Zen, Please follow the below steps, 1. "File" Menu -> "Open"-> PLL.v(IP created file) 2. Then Go to "File" ->"Create/ Update" -> "Create Verilog instantiation Template files for current file" 3.Check the "PLL.inst.v" file under project directory. Let me know if this has helped to resolve the issue. Regards, Vikas
ZLu001
Hi, Vikas.
when I use Quartus17 to open the PLL file( my is base_clock.v) the megawizad was appear and then the "Create Verilog instantiation Template files for current file" is grey out.
then I tried Quartus18, the file was opened at editor window and as you told, everything is fine.
Thank you very much.
