17249 Discussions
why different simulation outputs modelsim and simulation wave editor for ring osc..
Hello to everyone.
I apologize for disturbing you. I am trying to modeling ring oscillator in FPGA. You can see my design details in attached photo files.
  • At first modeled it schematically(photo1) then i run timing simulation it via simulation waveform editor/university program tools.
With this method i can see timing delays outputs(photo2 and photo3). when simulation results expanded outputs
  • Then i want to see my outputs delays in modelsim. For this purpose i convert my schematic design to .vhd file(file>create/update>create hdl design...). Then i use gate level simulation tool in quartus for modelsim. .... When I look at the results(photo4-->results, photo5-->zooming results) there is a problem.
The outputs of modelsim and university program quite different from each other. In modelsim the delay for the next output from the previous one logic delays periodically
increasing(photo 4 photo 5). But in simulation waveform editor/university program ring oscillator outputs logic delays not periodic(photo 2 photo3).
What is the main reason for this situation and which result is correct? i couldnt decided.
Can you share the .bdf file?
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
Ok, thanks for your interest, i sent it.
Yes, In simulation result we can see the difference.
This is because of the conversion(.bdf to .vhd/.v) which we are doing.
The conversion is adding some extra delay/logic which can be seen in RTL viewer because of which we are getting the different results.
Anand Raj Shankar
