wire Verilog to VHDL
Can anyone help me translate this from Verilog to VHDL:
wire [4:0] sub_wire0;
wire [0:0] sub_wire5 = 1'h0;
wire [0:0] sub_wire2 = sub_wire0[0:0];
wire [1:1] sub_wire1 = sub_wire0[1:1];
wire c1 = sub_wire1;
wire c0 = sub_wire2;
wire sub_wire3 = inclk0;
wire [1:0] sub_wire4 = {sub_wire5, sub_wire3};
This should do it:
LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY test IS PORT ( inclk0 : IN std_logic ); END ENTITY test; ARCHITECTURE rtl OF test IS SIGNAL sub_wire0 : std_logic_vector(4 DOWNTO 0); SIGNAL sub_wire5 : std_logic := '0'; SIGNAL sub_wire2 : std_logic_vector(0 DOWNTO 0); SIGNAL sub_wire1 : std_logic_vector(1 DOWNTO 1); SIGNAL c1 : std_logic; SIGNAL c0 : std_logic; SIGNAL sub_wire3 : std_logic; SIGNAL sub_wire4 : std_logic_vector(1 DOWNTO 0); BEGIN -- ARCHITECTURE rtl sub_wire2(0) <= sub_wire0(0); sub_wire1(1) <= sub_wire0(1); c1 <= sub_wire1(1); c0 <= sub_wire2(0); sub_wire3 <= inclk0; sub_wire4 <= sub_wire5 & sub_wire3; END ARCHITECTURE rtl;
But to be honest this code doesn't make much sense.
after a quick glance this looks correct
the code looks like it's machine generated to me, which is why it doesn't make sense
Is there any tool to convert from verilog to vhdl.
i have synapticad but i dont know how to convert it.
give some tools for HDL conversion.
vasireddyrajesh3 (http://www.alteraforum.com/forum/member.php?u=56700): Yes, X-HDL is a tool, but it wont work for files over 1024 bytes :mad:
schmalisch (http://www.alteraforum.com/forum/member.php?u=1078): Thank you for your help :)
Thank you for the info.
