Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
Pentium 8505 Proxmox/Opnsense QAT
DarrenL
New User
Hi. Currently trying to configure an industrial mini PC with a Pentium 8505. Ultimately we want to use QAT with OpenVPN but QAT doesn't seem to be available.
Proxmox version is 8.4.1
lscpu and lspci output below.
Any help appreciated.
Darren.
root@prox:~# lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 39 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 6
On-line CPU(s) list: 0-5
Vendor ID: GenuineIntel
BIOS Vendor ID: Intel(R) Corporation
Model name: Intel(R) Pentium(R) Gold 8505
BIOS Model name: Intel(R) Pentium(R) Gold 8505 To Be Filled By O.E.M. CPU @ 4.3GHz
BIOS CPU family: 11
CPU family: 6
Model: 154
Thread(s) per core: 2
Core(s) per socket: 5
Socket(s): 1
Stepping: 4
CPU(s) scaling MHz: 62%
CPU max MHz: 4400.0000
CPU min MHz: 400.0000
BogoMIPS: 4992.00
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_t
sc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma
cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp i
brs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsave
opt xsavec xgetbv1 xsaves split_lock_detect user_shstk avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi vnmi umip pku osp
ke waitpkg gfni vaes vpclmulqdq rdpid movdiri movdir64b fsrm md_clear serialize arch_lbr ibt flush_l1d arch_capabilities
Virtualization features:
Virtualization: VT-x
Caches (sum of all):
L1d: 176 KiB (5 instances)
L1i: 288 KiB (5 instances)
L2: 3.3 MiB (2 instances)
L3: 8 MiB (1 instance)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-5
Vulnerabilities:
Gather data sampling: Not affected
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Reg file data sampling: Vulnerable: No microcode
Retbleed: Not affected
Spec rstack overflow: Not affected
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; Enhanced / Automatic IBRS; IBPB conditional; RSB filling; PBRSB-eIBRS SW sequence; BHI BHI_DIS_S
Srbds: Not affected
Tsx async abort: Not affected
root@prox:~# lspci
00:00.0 Host bridge: Intel Corporation Core i9/i7/i5/i3 Host Bridge/DRAM Registers (rev 04)
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-UP3 GT1 [UHD Graphics] (rev 0c)
00:06.0 PCI bridge: Intel Corporation 12th Gen Core Processor PCI Express x4 Controller #0 (rev 04)
00:0a.0 Signal processing controller: Intel Corporation Platform Monitoring Technology (rev 01)
00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
00:17.0 SATA controller: Intel Corporation Alder Lake-P SATA AHCI Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation Alder Lake PCI Express x4 Root Port (rev 01)
00:1c.5 PCI bridge: Intel Corporation Alder Lake-P PCH PCIe Root Port (rev 01)
00:1c.6 PCI bridge: Intel Corporation Device 51be (rev 01)
00:1c.7 PCI bridge: Intel Corporation Alder Lake PCH-P PCI Express Root Port #9 (rev 01)
00:1d.0 PCI bridge: Intel Corporation Alder Lake PCI Express Root Port (rev 01)
00:1d.1 PCI bridge: Intel Corporation Alder Lake PCI Express x1 Root Port #10 (rev 01)
00:1f.0 ISA bridge: Intel Corporation Alder Lake PCH eSPI Controller (rev 01)
00:1f.3 Audio device: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. NV3 NVMe SSD TC2201 (DRAM-less)
02:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
03:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
04:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
05:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
06:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
07:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
DiegoV_Intel
Intel® Pentium® Processors do not have Intel® QuickAssist Technology (QAT) accelerators. QAT devices are included only in the latest Intel® Xeon® Processors (4th Gen and newer) depending on the model.
This is an example for your comparison between Intel® Pentium® Gold Processor 8505 and Intel® Xeon® Gold 6554S Processor. See under Advanced Technologies a line for Intel® QuickAssist Technology (QAT).
Diego V.
pquesinb
Apparently the 8505 does have it.  It's listed under Security & Reliability:
Intel® Threat Detection Technology (TDT)   Yes
Intel® Secure Key   Yes
Intel® QuickAssist Software Acceleration   Yes
DiegoV_Intel
The line Intel® QuickAssist Software Acceleration under Security & Reliability means that it's possible to use the QAT API, but since there is no dedicated QAT hardware, QAT operations will use CPU. There won't be real benefit of this approach since there is no QAT hardware to handle such operations.
On the other hand, processors that have QAT hardware available have listed Intel® QuickAssist Technology (QAT) under Advanced Technologies. In those processors that have dedicated QAT hardware, when using the QAT API, the operations will be run by such dedicated hardware instead of the CPU. In this case, the QAT devices will also be listed as PCI devices when running commands like lspci.
That's the difference between these two entries: Intel® QuickAssist Software Acceleration vs Intel® QuickAssist Technology (QAT) in the product spec page.
Diego V.
pquesinb
Very interesting (and misleading, sadly).  Many thanks for the clarification!
