Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
98 Discussions
QAT Service failed after build from QATLib Github source
OttoChow
The OS env. is Ubuntu 20.04 and the server HW is based on Xeon 5416S Server (2 Sockets).  I downloaded the QAT Driver Software package - QAT20.L.1.1.40-00018.tar.gz from Intel website.  I built the driver and QAT software, then install it as usual.
QAT Service can be started without issue.  QAT Manager can show that QAT accelerator end points are available.
After 2 days of working on data compression functions of QAT accelerator, there are some questions regarding to QATLIB function.  Overall, the HW functions as expected.
I found that there is a new release of QATLIB on Github.  I decided to have a go, download the source and build it.
Then QAT Service cannot be started and qatmgr reports "No devices found".  Nothing of QAT works.  However, if I reverse back to QAT20L ... package, everything is back to normal.
I tried to compare these two version of QAT software.  QAT20.L.1.1.40-0000=18, it starts the QAT Service by "ExecStart=/etc/init.d/qat_service start"; QATLIB from Github, it starts by "/usr/local/sbin/qatmgr --policy=${POLICY}.   Wondering whether that is the reason why  QAT Service does not start after updating with the Github version of QATLIB.
Anything I missed?
Otto
Ronny_G_Intel
Hi Otto,
There are two types of QAT driver, in-tree and out-of-tree.
If the qat driver is in kernel, it is in-tree otherwise it is out-of-tree.
If you use in-tree QAT driver then you install qatlib.
Make sure that the host and the guest all use in-tree qat driver.
You are using QAT20.L.1.1.40-00018.tar.gz which means out-of-tree driver.
If you want to use in-tree, before installing qatlib, you must uninstall the out-of-tree qat driver.
I hope this helps.
Ronny G
Ronny_G_Intel
Hi Otto,
I hope this helps.
Ronny G
