571 Discussions
Agilex 7 can HPS use HBM instead of DDR to connect to MPFE
chander
AGMF039 has 32GB of HBM. 16GB of HBM is on the same NoC as HPS. Is it possible for HPS to use this 16GB (or perhaps even 32GB) of HBM to be connected to its MPFE interface instead of DDR.
Is there any example design for the same?
JingyangTeh_Altera
Hi
Apologize for the late reply.
The HBM could not be connected through the MPFE other than AXI.
Jingyang, Teh
aikeu
Hi chander,
I dont see there is an example design for that.
Can search some of the example designs in the link below:
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/design-store.html
Aik Eu
chander
Thanks for the link, it contains some wonderful design examples, but unfortunately not what we need. Btw is it architecturally possible to have the HPS boot of the HBM instead of DDR  via the MPFE? If so can someone guide us how we can possibly achieve this.
aikeu
Hi chander,
There is no HBM reference guide for Agilex 7 HPS referring to Agilex 7 TRM.
https://www.intel.com/content/www/us/en/docs/programmable/683567/23-1/hard-processor-system-technical-reference.html
The available guide for building bootloader only uses DDR in the booting system.
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderAgilex7
Aik Eu
aikeu
Hi chander,
I will close the thread if no further question.
Aik Eu
chander
Thanks Aik Eu,
 Should we then conclude that its not technically feasible to have the HPS access HBM  via the MPFE?
 Or should we  conclude that while its possible , there are no examples or documentation for it ?
regards
Chander
JingyangTeh_Altera
Hi
There are a few method of configuring the Agilex7 listed below:
  • Configuration over JTAG
  • Configuration from QSPI
  • Configuration over AVST
  • Configuration via Protocol
  • Remote System Update (RSU)
https://www.intel.com/content/www/us/en/docs/programmable/683389/22-4/creating-the-configuration-files.html
The closes to your mentioned use case is to Configure over AVST. Where the Agilex7 is configured through the Avalon Stream by an Avalon Master.
Jingyang, Teh
JingyangTeh_Altera
Hi
Any update on this case?
Jingyang, Teh
chander
  The query was regarding the HPS being able to access the HBM over the MPFE interface rather than the AXI interface. The HPS can only access a 4GB address space over the HPS-to-FPGA AXI interface, however via the MPFE it can access 16GB address space or more. The query was if HPS can access the HBM via MPFE.
regards
Chander
JingyangTeh_Altera
Hi
Jingyang, Teh
chander
Thanks Jingyang Teh,
That helps answer the query.
regards
Chander
JingyangTeh_Altera
Hi
Do you have any follow up question for this case?
Jingyang, Teh
JingyangTeh_Altera
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
