573 Discussions
Agilex Ftile is not asserting tx_ready after the reset sequence (tx_rreset/tx_reset_ack)
MesbahKarim
    I build my controller model to Agilex F-tile transceiver. Please see the configuration below for F-tile and simulation waveform. Xcvr is asserting tx_reset/tx_reset_ack and rx_reset/rx_reset_ack and completing the reset sequence.  But it is not asserting tx_ready.  I used support logic generated by Quartus flow (6.7 user's guide).  My configuration is also RX de-skew disabled.
I could not find any reason not to getting tx_ready. Could you please help if anyone knows the answer please let me know. I am stuck at this point.  In the waveform tx_ready mapped to tx_pma_ready and rx_ready mapped rx_pma_ready.
Mesbah
Kshitij_Intel
Can you please check are you fulfilling the reset signal requirements? Please refer below link.
https://www.intel.com/content/www/us/en/docs/programmable/683872/22-4-4-3-0/reset-signal-requirements.html
Also, tx_reset and rx_reset input for TX/RX PMAs and TX/RX datapath. Must be kept asserted until tx_reset_ack and rx_reset_ack is asserted. Applies to all TX/RX channels in a F-Tile PMA/FEC Direct PHY Intel® FPGA IP instance.
Can you please clarify which Run-Time Reset Sequence you are following.
Thank you
Kshitij Goel
Kshitij_Intel
Do we have any update on this?
Thank you
Kshitij Goel
MesbahKarim
Hi K**bleep**ij,
   Thank you for your quick response.  Yes, I fulfilled the reset sequence that was described in  6.7.  I am getting  tx_reset_ack/rx_reset_ack, tx_pll_locked and rx_is_lockedtoref  but not tx_ready/rx_ready.  that I mentioned before.
I also noticed that when tx_pll_locked is asserted, tx_clkout2 stop toggling.   Please look at the at the waveform again, the run-time reset sequence is following as indicated in 3.8.8  except asserting tx_ready/rx_ready
I am using Questasim simulator.   I am using FAST_SIM directive. Please let me know, if I am missing something.
Appreciate your response. I am still stuck at this point.
Mesbah
MesbahKarim
Sorry K**bleep**ij for the typo in your name,
Mesbah
MesbahKarim
Sorry again K**bleep**ij,
Kshitij_Intel
Are you getting tx_reset_ack and rx_reset_ack?
tx_ready will assert when TX PMA and TX datapath are reset successfully and ready for data transfer.
and rx_ready will assert when RX PMA and RX datapath are reset successfully and ready for data transfer, If RX de-skew is disabled.
Note: During F-Tile link initialization, the data pattern sent from the TX has to be scrambled to get rx_ready to assert. If a 0101 pattern or other constant patterns are sent, rx_ready does not assert, and the link does not initialize.
tx_ready and rx_ready will assert when reset has been done successfully.
Thank you
Kshitij Goel
MesbahKarim
Hi Goel,
          Yes, I am getting tx_reset_ack and rx_reset_ack.
Could please clarify Red bold part. I am getting tx_reset_ack/rx_reset_ack. Does not  it mean TX PMA and TX data path are reset successfully?
I am going to run with TX  scrambled data pattern to see rx_ready
Mesbah
Kshitij_Intel
Can you please generate an example design and take a reference of it.
https://www.intel.com/content/www/us/en/docs/programmable/683872/22-4-4-3-0/example-design-generation.html
If you still face issue please let me know.
Thank you
Kshitij Goel
MesbahKarim
Hi Goel,
         I am using latest released Quartus version 22.4.  I can generate only example design of "FHT NRZ 25G 1 PMA lane RSFEC 272/258"
My configuration is closer to "FGT NRZ 50G 2 PMA lanes RSFEC 528/514" but could not run as it did generate support_logic.
My configuration is "FGT NRZ 25G 8 PMA lanes."  without RSFEC
Mesbah
MesbahKarim
Sorry, typo it did not generate support_logic
Mesbah
Kshitij_Intel
Hi Mesbah,
Can you please share your project, so that I can look into the issue.
Thank you
Kshitij Goel
MesbahKarim
Hi Goel,
  Sorry for the late response. I was waiting for Quartus 23.1 to release and use it  We just received it and IT is i
Do you want whole project?  I sent you the F-Tile configuration.  My project includes our IP blocks.
This is not loopback  model.   Our IP has also Serdes. This is a communication between to Serdes.
We want F-Tile transceiver is ready to communicate with another Serdes. Do  you have any example design of that configuration that I mentioned in my first correspondence? even loopback is also fine.  Please share with me.  Quartus project have a few example_design. I can not configure with my configuration and generate example design.  If you have please share with me
Mesbah
jmcguire3
I'm experiencing this same symptom.  I have created another thread with details because I suspect this discussion is dead.
https://community.intel.com/t5/Programmable-Devices/Agilex-F-Tile-tx-ready-fails-to-assert/m-p/1559874#M94135
Bumpity, bump.
