568 Discussions
Any Cyclone V soc bare metal startup project settings available?
CAlex
New Contributor II
I successfully ran the sample on the rocketboards,
now I want to make my own project,
do you guys have any setting guide for that?
Reguards.
CAlex
New Contributor II
I cant even load the spl, it means it cant start at DDR. Once I could but now I cant witht the same steps.
The ds file is form the cycloneV soc hwlib example from rocketboards.org
If you succeeded by windows, could you please share the GHRD software folder?
My environemnt is :
SOCEDS standard 20.1
ARM DS 21.1 evaluation
Quartus 22.1lite
WSL2 ubuntu 20.04 LTS
CAlex
New Contributor II
I solved it, I used the older version U-boot(like the example said 2020.04 would work).
The newest version 2023.0~2022.10 cant work under my environment though.
You guys may want to test and fix this maybe?
Reguards
aikeu
Hi CAlex,
I didnt face the issue of using the latest u-boot. Is it related to compilation issue?
May I know what is the current state of troubleshooting on ur side?
Aik Eu
CAlex
New Contributor II
Yes,
when I use the newest u-boot version and loaded the u-boot-spl the cycloneV soc dev kit board didnt work. I made the u-boot by arm-eabi-gcc linaro 7.5.0 i686 minGW64.
And I start to use the 2020.04 version and build the u-boot on my another computer(Linux version with Ubuntu 22.04LTS). The spl finally worked.
I dont know what is the reason but you may have that a try.
BTW, I downloaded the linaro zip file direct from the github and copy the newlib I installed before for my intelnet here is too bad to finish the whole download.
I can try to run the whole ./install_linaro.sh when Im free and try again for that case.
I hope this may help.
aikeu
Hi CAlex,
Good to hear that part of the issue has been solved on your side.
Do let me know regarding the further follow up on your side.
Aik Eu
aikeu
Hi CAlex,
Do let me know if there is an update on your side.
Aik Eu
aikeu
Hi CAlex,
Do let me know if you already have some follow up regarding your previous working state.
Aik Eu
CAlex
New Contributor II
Sorry I dont have time right now for other issues of the project.
And since this issue no longer bothers me you can do what you must to this thread.
Thank you.
aikeu
Hi CAlex,
Thanks for the respond. I will close this thread for now.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Aik Eu
