Arria 10 SoC - Boot from QSPI
fpga_2022
hi,
I went through the manual to get all the files to boot from QSPI, but now the boot is stuck, does anyone know how to deal with it?
KennyTan_Altera
Thanks for using Intel community forum,
Kindly expect some delay in the reply due to holiday.
Kenny
JingyangTeh_Altera
Hi fpga_2022
Is the manual you are referring to the steps in Rocketboard ( https://rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10#Arria_10_SoC_45_Boot_from_QSPI) ?
While flashing the binaries into the QSPI did you flash it using the "quartus_hps" tool or did you manually write them in the U-Boot?
Did you met any errors while you are running any of the steps?
Jingyang, Teh
JingyangTeh_Altera
Hi fpga_2022
Any update on this case?
Jingyang, Teh
JingyangTeh_Altera
Hi fpga_2022
I will be closing this case as you have created another forum case for this issue.
https://community.intel.com/t5/Intel-SoC-FPGA-Embedded/Arria-10-SoC-Boot-from-Qspi/m-p/1401870#M1408
If you still need further assistance, you are welcome reopen this case within 20days or open a new case, someone will be right with you.
Jingyang, Teh
