Arria 10 SoC - Boot from Qspi
fpga_2022
hi ,
   I downloaded Zimage and dtb files to flash, stuck here after booting。and I upload the boot information in boot.txt。Can anyone help me with this problem?
   I can't reply to messages, can communicate via email。
U-Boot 2014.10 (Jul 18 2022 - 23:29:51)
CPU : Altera SOCFPGA Arria 10 Platform
BOARD : Altera SOCFPGA Arria 10 Dev Kit
I2C: ready
DRAM: WARNING: Caches not enabled
SF: Read data capture delay calibrated to 1 (0 - 2)
SF: Detected N25Q1024A with page size 256 Bytes, erase size 4 KiB, total 128 MiB
DDRCAL: Success
INFO : Skip relocation as SDRAM is non secure memory
Reserving 2048 Bytes for IRQ stack at: ffe3a6e8
DRAM : 2 GiB
lay calibrated to 8 (0 - 15)
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Model: SOCFPGA Arria10 Dev Kit
Net: dwmac.ff800000
Hit any key to stop autoboot: 0
FPGA must be in Early Release mode to program core.
fpga - loadable FPGA image support
SF: 6225920 bytes @ 0x120000 Read: OK
SF: 32512 bytes @ 0x100000 Read: OK
FPGA BRIDGES: enable
Kernel image @ 0x008000 [ 0x000000 - 0x534158 ]
## Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x000100
Loading Device Tree to 01ff6000, end 01fff3de ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.110-79522-ga42b99492a81-dirty (hh@ubuntu) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.1 20220111, GNU ld (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 2.37.20220122) #1 SMP Sun Jun 19 23:43:49 PDT 2022
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Altera SOCFPGA Arria 10
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] percpu: Embedded 19 pages/cpu s45260 r8192 d24372 u77824
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522752
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock1 rw rootfstype=jffs2
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.00
JingyangTeh_Altera
Hi fpga_2022
I tried contacting you through email yesterday with the email address 406313397@qq.com
Could you drop me a mail if the email address is not valid.
My email address is jingyang.teh@intel.com
Jingyang, Teh
JingyangTeh_Altera
Hi fpga_2022
Since there are no feedback for this thread or to ,email I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, someone will be right with you.
If you happened to close this thread you might receive a survey.  If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
