573 Discussions
COT BOM-2, Request for part status information
Bireshwar
Hello Intel Team,
We are unable to find the part status of below mentioned MPN. Please provide us the current part status (Active, NRND, EOL or Obsolete) and Availability.
So we would like to know the below information for the mentioned part, it is really appreciated if you could help us with the details.
PEF22552EV1.1-GIC,DUAL E1/T1/J1 LINE INT,PPG-LBGA-160-1
EP4CE55F23I8LNIC,FPGA,EP4CE55,324I/O,CYCLON-IV,FBGA-484
EPCS4SI8NIC,FLASH,4Mb,SERIAL,SOIC-8
EP4CE6E22I7NIC,FPGA,EP4CE6,91 I/O,6272 LE,EQFP-144
EP2C70F672I8NIC,FPGA,EP2C70,422I/O,CYCLON II,FBGA-672
5M570ZF256I5NIC,FPGA,5M570Z,MAX V,FBGA-256
946587IC,DUAL E1/T1/J1 LINE INT,PPG-LBGA-160-1
PEF22552EV11IC,DUAL E1/T1/J1 LINE INT,PPG-LBGA-160-1
EPCQ4ASI8NIC,FLASH,4Mb,SERIAL,SOIC-8
Thanks and Regards,
Bireshwar B Beladhadi
Component Engineer
PH:+91 9742490090
Cyient | www.cyient.com |email: Bireshwarb.beladhadi@cyient.com
NazrulNaim_Intel
Sorry for the delay. Below is the information needed for the devices.
EP4CE55F23I8LN = Active
EPCS4SI8N = EOL
EP4CE6E22I7N = Active
EP2C70F672I8N = Active
5M570ZF256I5N = Active
Hope that answers your question.
For the other devices, this tech support is focusing on Intel FPGA family. Unfortunately, we can't support any issue that is not related to FPGA.
Sorry for the inconvenience.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
Nazrul Naim
