569 Discussions
Cadence のncverilog に組み込むとaxi_set_master_end_abstraction_level が発生します。
HShim17
 Cadence のncverilog に組み込むと以下のエラーが発生します。
ncsim: *F,NOLWSV: Searching for import subroutine "axi_set_master_end_abstraction_level" in default library libdpi. Unable to load the default library libdpi.
OSDLERROR: ./libdpi.so: cannot open shared object file: No such file or directory or file is not valid ELFCLASS64 library..
KennyTan_Altera
May I know what OS that you were using? This seems to be missing library when you use the tools.
KennyTan_Altera
any update?
