573 Discussions
Cyclone V FPGA HPS2FPGA Lightweight bridge timing requirement
Peter78759
I am working on developing the interface between the HPS and our FPGA design through the HPS2FPGA Lightweight bridge, which uses the AXI lite bus protocol. This protocol includes some handshaking control between the master and the slave. I have made some progress and am able to write to a register in the FPGA. However, the write operation cannot be completed. It appears that the HPS is waiting for confirmation. I used Quartus SignalTap (a software logic analyzer) to analyze the timing and found that my design module does send the confirmation to the HPS. Most likely, the problem is caused by some timing requirements for the HPS. I can’t find a document that explains the detailed timing requirements about this interface. I would greatly appreciate your feedback Thanks, Peter.
I hope to understand the timing requirements for following signals:
                              output wire [11:0] hps_0_h2f_lw_axi_master_awid,          //   hps_0_h2f_lw_axi_master.awid
                              output wire [20:0] hps_0_h2f_lw_axi_master_awaddr,        //                          .awaddr
                              output wire [3:0]  hps_0_h2f_lw_axi_master_awlen,         //                          .awlen
                              output wire [2:0]  hps_0_h2f_lw_axi_master_awsize,        //                          .awsize
                              output wire [1:0]  hps_0_h2f_lw_axi_master_awburst,       //                          .awburst
                              output wire [1:0]  hps_0_h2f_lw_axi_master_awlock,        //                          .awlock
                              output wire [3:0]  hps_0_h2f_lw_axi_master_awcache,       //                          .awcache
                              output wire [2:0]  hps_0_h2f_lw_axi_master_awprot,        //                          .awprot
                              output wire        hps_0_h2f_lw_axi_master_awvalid,       //                          .awvalid
                              input  wire        hps_0_h2f_lw_axi_master_awready,       //                          .awready
                              output wire [11:0] hps_0_h2f_lw_axi_master_wid,           //                          .wid
                              output wire [31:0] hps_0_h2f_lw_axi_master_wdata,         //                          .wdata
                              output wire [3:0]  hps_0_h2f_lw_axi_master_wstrb,         //                          .wstrb
                              output wire        hps_0_h2f_lw_axi_master_wlast,         //                          .wlast
                              output wire        hps_0_h2f_lw_axi_master_wvalid,        //                          .wvalid
                              input  wire        hps_0_h2f_lw_axi_master_wready,        //                          .wready
                              input  wire [11:0] hps_0_h2f_lw_axi_master_bid,           //                          .bid
                              input  wire [1:0]  hps_0_h2f_lw_axi_master_bresp,         //                          .bresp
                              input  wire        hps_0_h2f_lw_axi_master_bvalid,        //                          .bvalid
                              output wire        hps_0_h2f_lw_axi_master_bready,        //                          .bready
                              output wire [11:0] hps_0_h2f_lw_axi_master_arid,          //                          .arid
                              output wire [20:0] hps_0_h2f_lw_axi_master_araddr,        //                          .araddr
                              output wire [3:0]  hps_0_h2f_lw_axi_master_arlen,         //                          .arlen
                              output wire [2:0]  hps_0_h2f_lw_axi_master_arsize,        //                          .arsize
                              output wire [1:0]  hps_0_h2f_lw_axi_master_arburst,       //                          .arburst
                              output wire [1:0]  hps_0_h2f_lw_axi_master_arlock,        //                          .arlock
                              output wire [3:0]  hps_0_h2f_lw_axi_master_arcache,       //                          .arcache
                              output wire [2:0]  hps_0_h2f_lw_axi_master_arprot,        //                          .arprot
                              output wire        hps_0_h2f_lw_axi_master_arvalid,       //                          .arvalid
                              input  wire        hps_0_h2f_lw_axi_master_arready,       //                          .arready
                              input  wire [11:0] hps_0_h2f_lw_axi_master_rid,           //                          .rid
                              input  wire [31:0] hps_0_h2f_lw_axi_master_rdata,         //                          .rdata
                              input  wire [1:0]  hps_0_h2f_lw_axi_master_rresp,         //                          .rresp
                              input  wire        hps_0_h2f_lw_axi_master_rlast,         //                          .rlast
                              input  wire        hps_0_h2f_lw_axi_master_rvalid,        //                          .rvalid
                              output wire        hps_0_h2f_lw_axi_master_rready,        //                          .rready
aikeu
Hi Peter78759,
I think this rocketboards link may help for your issue:
https://forum.rocketboards.org/t/qsys-logic-for-creating-a-hps2fpga-com/1411
Aik Eu
aikeu
Hi Peter78759,
I will close the thread if no further question.
Aik Eu
