573 Discussions
How do I get u-boot-with-spl.sfp to read u-boot.scr instead of extlinux.conf?
JMurr12
Using SoCEDS 19.1
FawazJ_Altera
This is the default setup for uboot.
once you have the uboot source code, you can navigate to inculde/configs/socfpga_common.h file
inside this file, you can see the default uboot environments. for example:
#define CONFIG_EXTRA_ENV_SETTINGS \
"verify=n\0" \
"loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
"fdtaddr=0x00000100\0" \
"bootimage=zImage\0" \
"bootimagesize=0x600000\0" \
"fdtimage=socfpga.dtb\0" \
"fdtimagesize=0x7000\0" \
"mmcloadcmd=fatload\0" \
"mmcloadpart=1\0" \
"mmcroot=/dev/mmcblk0p2\0" \
"qspiloadcs=0\0" \
"qspibootimageaddr=0xa0000\0" \
"qspifdtaddr=0x50000\0" \
"qspiroot=/dev/mtdblock1\0" \
"qspirootfstype=jffs2\0" \
"nandbootimageaddr=0x120000\0" \
"nandfdtaddr=0xA0000\0" \
"nandroot=/dev/mtdblock1\0" \
"nandrootfstype=jffs2\0" \
"ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \
"bootz ${loadaddr} - ${fdtaddr}\0" \
"mmcload=mmc rescan;" \
"${mmcloadcmd} mmc 0:${mmcloadpart} ${loadaddr} ${bootimage};" \
"${mmcloadcmd} mmc 0:${mmcloadpart} ${fdtaddr} ${fdtimage}\0" \
"mmcboot=setenv bootargs " CONFIG_BOOTARGS \
" root=${mmcroot} rw rootwait;" \
"netboot=dhcp ${bootimage} ; " \
"tftp ${fdtaddr} ${fdtimage} ; run ramboot\0" \
"qspiload=sf probe ${qspiloadcs};" \
"sf read ${loadaddr} ${qspibootimageaddr} ${bootimagesize};" \
"sf read ${fdtaddr} ${qspifdtaddr} ${fdtimagesize};\0" \
"qspiboot=setenv bootargs " CONFIG_BOOTARGS \
" root=${qspiroot} rw rootfstype=${qspirootfstype};"\
"nandload=nand read ${loadaddr} ${nandbootimageaddr} ${bootimagesize};"\
"nand read ${fdtaddr} ${nandfdtaddr} ${fdtimagesize}\0" \
"nandboot=setenv bootargs " CONFIG_BOOTARGS \
" root=${nandroot} rw rootfstype=${nandrootfstype};"\
"fpga=0\0" \
"fpgadata=0x2000000\0" \
"fpgadatasize=0x700000\0" \
CONFIG_KSZ9021_CLK_SKEW_ENV "=" \
__stringify(CONFIG_KSZ9021_CLK_SKEW_VAL) "\0" \
CONFIG_KSZ9021_DATA_SKEW_ENV "=" \
__stringify(CONFIG_KSZ9021_DATA_SKEW_VAL) "\0" \
"scriptfile=u-boot.scr\0" \
"callscript=if fatload mmc 0:1 $fpgadata $scriptfile;" \
"then source $fpgadata; " \
the above snapshot of code was taken from the socfpga_common.h, and this line show the default script name:
if you need to change any environment setup from the default one, you need to modify this file, then compile uboot.
in case you need to read from .conf file, you can remove the .scr file and the uboot will read the .conf file automatically.
Hope this might help.
thanks.
JMurr12
My version of socfpga_common.h was Copyright 2012 and CONFIG_EXTRA_ENV_SETTINGS was
#ifndef CONFIG_EXTRA_ENV_SETTINGS
    "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
    "bootm_size=0xa000000\0" \
    "kernel_addr_r="__stringify(CONFIG_SYS_LOAD_ADDR)"\0" \
    "fdt_addr_r=0x02000000\0" \
    "scriptaddr=0x02100000\0" \
    "pxefile_addr_r=0x02200000\0" \
    "ramdisk_addr_r=0x02300000\0" \
    "socfpga_legacy_reset_compat=1\0" \
    BOOTENV
#endif
I obtained this following the instructions at https://rocketboards.org/foswiki/Documentation/BuildingBootloader
git clone https://github.com/altera-opensource/u-boot-socfpga
when I issue this command, I get a version of socfpga_common.h copyright 2013-2015 where CONFIG_EXTRA_ENV_SETTINGS matches yours pretty closely.
When I issue the following commands,
cd u-boot-socfpga
git checkout -t -b test origin/socfpga_v2019.04
I get the Copyright 2012 version and CONFIG_EXTRA_ENV_SETTINGS as above.
Are these the wrong instructions? Can you point me to something more accurate?
Thanks again.
FawazJ_Altera
Hello sir,
you are doing it perfectly.
This is the file you are referring to:
https://github.com/altera-opensource/u-boot-socfpga/blob/0c9a3bdf3ca1326e3bc539676452f2d4f8895aeb/include/configs/socfpga_common.h
the copyright years wont be changed unless there is an update.
I will send you an email.
Thank you
