573 Discussions
How to configure device tree and defconfig for using USB device?
sunyeong
I'm using an Agilex 5E Premium Development kit board.
I'm trying to communicate with my PC via USB, and I'm planning to use this device as a device(gadget).
Can you tell me how to configure defconfig, device tree, etc. for this?
Jung.
Jeet14
sunyeong
Hi, Jeet14.
Thanks for comment.
As I know, some configuration needs for using Gadget Serial feature like below url.
https://www.rocketboards.org/foswiki/Documentation/REFLEXCESAchillesArria10SoCSOM
Can I use the usb-gadget.cfg mentioned in this document as Agilex5 kernel configuration?
In device tree, the "dr_mode" property in usb node have to be added as I know.
This property can be configured as "peripheral", "otg", or "host".
Which value shoud I use?
Jung.
Jeet14
You need to use the dr_mode as "host".
I believe you are using the board USB as Host through which you are connecting the USB devices.
Tiwari
sunyeong
I think that there is some miss commnunication.
I said that I want to use the Developlment Kit as a gadget(device).
And I will use My PC as a HOST.
(FYI, In USB communication, there is a host/gadget concept.
It is concept like between master/slave.)
So, setting up a development board to act as a host seems a little different than what I'm asking for.
Jung.
Jeet14
Apologies for delayed response.
Then you need to use the "peripheral" mode, as the PC will be the host.
Tiwari
Jeet14
Hi
Please let me know if there is any query on this.
Tiwari
Jeet14
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
sunyeong
It's been so long time since I asked. So I forgot this issue.
It took almost a month to get this answer....
The Devkit that I use is ES version.
It seems that this board doesn't support USB 3.1 like below.
So I can't check this feature for now.
Thank you.
Regards.
