573 Discussions
How to convert Prime 18.1 "Pro" IP to "Standard" IP ?
mtgavin
I used Intel HLS (v18.1) to generate some IP, using the Prime "Pro" version.
Unfortunately, my top level design (where I would like to put the IP) is in "standard" version.
Is there a way to convert the 18.1 "Pro" version IP to "Standard" version IP so I can use it in my "Standard" design?
I am having problems using HLS in "Standard" version, due to the C++ library versions it requires, so it won't be easy for me to just regenerate the IP in HLS "Standard" version.  (I can't get that to work.)
MuhammadAr_U_Intel
Hi, Only option I can think of is to re-generate using Quartus Standard HLS. Is the top level design RTL based or Qsys based ? Have you considered moving the top level design to Pro Edition ? Thanks, Arslan
mtgavin
I have figured out how to use HLS Standard edition. This works better with a Red Hat 6 machine, that has the right C libraries. So I will use that in my top level design. Thanks.
