573 Discussions
I try to connect HPS with FPGA part in SOC_DE1 but I get this error I wonder if you could please help with that?
RMoha17
Abe
Valued Contributor II
Can you share the main C code file, so that we can take look at it. I've tried compiling the sources for ARM and it compiles fine. By the way, why are you using the Arria10 SoC kit files for CycloneV?
for basic examples of HPS SW you can look at the following path:
/cygdrive/c/intelFPGA/17.1/embedded/examples/software
RMoha17
Hello Thanks for reply I sent the codes. sorry I am not using Arria 10 SoC kit files!!!!!
EBERLAZARE_I_Intel
I'm not quite sure what your design is, are you trying to turn LEDs on and off just to show using the communication between the HPS and FPGA?
Regards.
