573 Discussions
Other workflow for generating Preloader since Quartus-Prime Version 19.1 with "SoC EDS 19.1 Command Shell„
GQUIR2
I work with FPGA-Eval-Board DE10-Standard from Terasic with Cyclone V and HPS.
Before Quartus-Prime Version 19.1 workflow in "SoC EDS 18.1 Command Shell„ was:
Generate the "Preloader" using the BSP Editor
Change to Quartus Project folder:
bsp-editor.exe &
File, New ..\hps_isw_handoff\soc_system_hps_0
Generate --> ..\software\spl_bsp is generated !!
Build the "Preloader„:
Change to folder ..\software\spl_bsp
>make
--> preloader-mkpimage.bin is generated !!
SoC EDS 19.1 Command Shell„ :
bsp-editor.exe &
>make
I get the message:
"Please visit https://rocketboards.org/foswiki/Documentation/BuildingBootloader for instructions on how to build the bootloader."
But on this page I couldn't find any instuction to generate Preloader "preloader-mkpimage.bin".
Can anyone help???
Does anyone know if generation of preloader-mkpimage.bin in all future versions Quartus not exist.
Thanks for any answer.
Gerhard
EBERLAZARE_I_Intel
Hi Gerhard,
For confirmation, are you using the Standard or Pro version of SoC EDS 19.1?
Eber.
GQUIR2
I am using “Intel FPGA Embedded Command Shell, Version 19.1 [Build 670]” and “Quartus Prime Version 19.1.0 Build 670 09/22/2019 Standard Edition”. Best Regards Gerhard
EBERLAZARE_I_Intel
Hi Gerhard,
Regarding the preloader mkpimage bin file generation in https://rocketboards.org/foswiki/Documentation/BuildingBootloader, we are currently looking into the issue.
Will update you once the issue is fixed.
Regards.
GQUIR2
When i follow the Steps at Documentation "Building Bootloader" at Rocketboards, i get problems when i try to make socfpga_cyclone5_defconfig !!!!
$ make socfpga_cyclone5_defconfig
 HOSTCC scripts/basic/fixdep
In Datei, eingebunden von scripts/basic/fixdep.c:115:
scripts/basic/fixdep.c: In Funktion »parse_config_file«:
scripts/basic/fixdep.c:241:18: Warnung: Arrayindex hat Typ »char« [-Wchar-subscripts]
 241 |  if (!(isalnum(*q) || *q == '_'))
process_begin: CreateProcess(NULL, /usr/bin/sh ./scripts/kconfig/lxdialog/check-lxdialog.sh -ccflags, ...) failed.
process_begin: CreateProcess(NULL, /usr/bin/sh ./scripts/kconfig/check.sh cc -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer -ansi, ...) failed.
 HOSTCC scripts/kconfig/conf.o
In Datei, eingebunden von scripts/kconfig/expr.h:15,
               von scripts/kconfig/lkc.h:9,
               von scripts/kconfig/conf.c:19:
scripts/kconfig/list.h:71:14: Fehler: expected »;« before »int«
 71 | static inline int list_empty(const struct list_head *head)
scripts/kconfig/list.h:82:14: Fehler: expected »;« before »void«
 82 | static inline void __list_add(struct list_head *_new,
scripts/kconfig/lkc.h:148:8: Fehler: unbekannter Typname: »inline«
 148 | static inline tristate sym_get_tristate_value(struct symbol *sym)
scripts/kconfig/lkc.h:154:14: Fehler: expected »;« before »struct«
 154 | static inline struct symbol *sym_get_choice_value(struct symbol *sym)
scripts/kconfig/lkc.h:159:14: Fehler: expected »;« before »_Bool«
 159 | static inline bool sym_set_choice_value(struct symbol *ch, struct symbol *chval)
scripts/kconfig/lkc.h:179:14: Fehler: expected »;« before »_Bool«
 179 | static inline bool sym_has_value(struct symbol *sym)
In Datei, eingebunden von scripts/kconfig/conf.c:7:
scripts/kconfig/conf.c: In Funktion »strip«:
scripts/kconfig/conf.c:62:18: Warnung: Arrayindex hat Typ »char« [-Wchar-subscripts]
 62 | while ((isspace(*p)))
scripts/kconfig/conf.c:70:18: Warnung: Arrayindex hat Typ »char« [-Wchar-subscripts]
 70 | while ((isspace(*p)))
scripts/kconfig/conf.c: In Funktion »conf_sym«:
scripts/kconfig/conf.c:173:12: Warnung: Implizite Deklaration der Funktion »sym_get_tristate_value«; meinten Sie »sym_set_tristate_value«? [-Wimplicit-function-declaration]
 173 | oldval = sym_get_tristate_value(sym);
    |          sym_set_tristate_value
scripts/kconfig/conf.c: In Funktion »conf_choice«:
scripts/kconfig/conf.c:313:25: Warnung: Arrayindex hat Typ »char« [-Wchar-subscripts]
 313 |  else if (isdigit(line[0]))
scripts/kconfig/conf.c: In Funktion »main«:
scripts/kconfig/conf.c:568:2: Fehler: C++-Stil-Kommentare sind in ISO-C90 nicht erlaubt
 568 | //zconfdump(stdout);
scripts/kconfig/conf.c:568:2: Anmerkung: (dies wird nur einmal pro Eingabedatei gemeldet)
make[1]: *** [scripts/kconfig/conf.o] Error 1
make: *** [socfpga_cyclone5_defconfig] Error 2
The whole bug report is in attachment. Has anyone an idea, what the problem is ?????
Gerhard
EBERLAZARE_I_Intel
Hi Gerhard,
Have you downloaded and setup the toolchain?
If you have, you will still need to execute the 3 exports which is the export PATH, export CROSS_COMPILE etc.. before executing the make.
Let me know if this does not fix the issue.
GQUIR2
I'm using "EDS Command Shell" running on Win 10 PC. How can I check if correct Toolchain is installed?
Is there manual how to install toolchain under "EDS Command Shell"?
Gerhard
EBERLAZARE_I_Intel
Unfortunately, the building bootloader tutorial is targeting for Linux host users it is not meant for Windows 10 users.
If you opt to use Windows 10, I recommend that you use Quartus and SoC EDS 18.1 std, and use the bsp-editor flow.
EBERLAZARE_I_Intel
If you wish to, you may install a virtual machine and learn Linux, it is pretty simple since you are going to use Linux in Cyclone V SoC anyway.
Regards.
EBERLAZARE_I_Intel
Do you have any follow up from your side?
