569 Discussions
Problem configuring PCIe Endpoint on Stratix10 MX Development Kit
Salma_M_Intel
I am using the Stratix 10 MX Development Kit. I am using an Example Design I generated in Quartus for “Avalon Memory Mapped (Avalon-MM) Intel Stratix 10 Hard IP+ for PCI Express”. I am using Quartus 19.4
I get this error on programming at about 80% done:
Error: Device has stopped receiving configuration data
Error message received from device : Device is in configuration state
Operation failed
Googling finds this workaround:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2019/error---device-has-stopped-receiving-configuration-data-error-me.html
To avoid this error and to enable 3V IOs in a design targeting any variant of Intel Stratix 10 FPGAs, power up the VCCR_GXB and VCCH_GXB rails of the respective transceiver tile as per the Intel Stratix 10 Device Family Pin Connection Guidelines.
How is this workaround implemented?
SengKok_L_Intel
This is to let you know that we tested 1SM21BHU2F53E1VG with the Avalon-MM design that generated from the PCIe GUI. It is working fine. The 1SM21BHU2F53E2VGS1 is the engineering sample device, and this board is currently not available for testing.
When you generate the example design from the PCIe IP AVMM GUI, did you select "Stratix 10 MX H-Tile ES1 FPGA Development Kit"?
Regards -SK
Salma_M_Intel
Please find attached my qsf file. Could somebody also please double-check the refclk and perst assignments?
Salma_M_Intel
I would appreciate a reference example that works using the Stratix MX using Avalon Memory Mapped (Avalon-MM) Intel Stratix 10 Hard IP+ for PCI Express”.
The part number is 1SM21BHU2F53E2VGS1. I am using the SMX Kit listed on this page: https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-s10-mx.html
SengKok_L_Intel
Regards -SK
Salma_M_Intel
This is silly but there was a problem with the power adapter.
After fixing it, the example works.
SengKok_L_Intel
Since the issue was resolved, I will set this forum case to close-pending for now. The status will remain in this state for 20 calendar days, simply post a note in this forum and it will be reopened for further investigation.
Regards -SK
