SOC EDS installation issue
Rainwang
New Contributor II
we are planning a project base on Arria 10 SOC FPGA, and for this device,  handbook suggest to use Quartus prime pro version rather than standard version.
because we need to develp ARM firmware, both Quartus prime and SOC EDS are needed.
From Intel website, I downloaded the Quartus Prime Pro V21.4, but I can't find the corresponding version SOC EDS, the newest version on the website is 20.1.
My question is:
1.  Can i install the Quartus Prime Pro V21.4 with SOC EDS V20.1? Someone told me it is better to install the Quartus and SOC EDS with the same version, is this right?
2. Where can i find the SOC EDS V21.4?
3. Or, if SOC EDS V21.4 is not available, shall i need to download Quartus Prime Pro V20.1 so that it has the same version as the newest SOC EDS?
4. Does intel has instruction document for above questions?
thanks.
Rainwang
New Contributor II
i doubt my corporation firewall blocked the file download, and i tried to download the file "alternatives-1.3.30c-10.tar.bz2" from the link per the setup.log, then copy it to the foler: "C:\intelFPGA_pro\20.1\embedded\cygwin_setup\https%3a%2f%2fcygwin.mirrors.hoobly.com%2f\x86_64\release\alternatives"
after these done, i tried to run the command again, now the cygwin was installed successfully!
now i believe this case can be closed and thanks for your support.
-----log as below-----
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\bash.exe --norc --noprofile "/etc/postinstall/zp_hicolor-icon-theme.sh"
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\dash.exe "/etc/postinstall/zp_man-db-update-index.dash"
running: C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\bin\bash.exe --norc --noprofile "/etc/postinstall/zp_shared-mime-info.sh"
Changing gid to Administrators
Ending cygwin install
C:\intelFPGA_pro\20.1\embedded\cygwin_setup>
YEan
1. The latest version available for SoC EDS Pro is v20.1. It is compatible to work with any version of Quartus Prime Pro Software.
2.  SOC EDS v21.4 was not available currently.
3. It is not compulsory. You may use SoC EDS Pro is v20.1 with Quartus Prime Pro v21.4.
4. We don't have documentation for questions above currently.
Ean
Rainwang
New Contributor II
Thank you for your reply.
Now i have installed Quartus prime pro V21.4 on my laptop(win10 OS).
and i am installing the SOC EDS v20.1 per instructions on below link:
https://rocketboards.org/foswiki/Documentation/SoCEDS#Install_SoC_EDS_AN1
I have installed the SOC EDS and ARM DS already.
now i am installing the Cygwin but error occurs with below logs. i tried several times with the same error. Will you pls help to check the reason and tell me how to do the next step?
-------------------error logs below-------------------------
2022/03/10 13:45:57 Downloaded C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/subversion/subversion-1.14.1-1.tar.xz
2022/03/10 13:45:57 download error in unattended_mode: 4 retries remaining.
get_url_to_file https://cygwin.mirrors.hoobly.com/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz.tmp
Checking SHA512 for file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz
SHA512 verified OK: file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz 410b9d6dc8736f26350772da311d97f6f7a28e24e0c1f9ca2ece5eed6bf1758ab8a56f55e89affc784e0f28db90a5b170f384462a2b57f26a9f73ee971577e49
2022/03/10 13:46:11 Downloaded C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/noarch/release/mingw64-x86_64-headers/mingw64-x86_64-headers-9.0.0-1.tar.xz
get_url_to_file https://cygwin.mirrors.hoobly.com/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2.tmp
INVALID PACKAGE: file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 - Size mismatch: Ini-file: 73505 != On-disk: 10525
2022/03/10 13:46:14 Downloaded file C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 is corrupt; deleting.
2022/03/10 13:46:14 download error in unattended_mode: 3 retries remaining.
INVALID PACKAGE: file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 - Size mismatch: Ini-file: 73505 != On-disk: 10521
2022/03/10 13:46:16 Downloaded file C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 is corrupt; deleting.
2022/03/10 13:46:16 download error in unattended_mode: 2 retries remaining.
INVALID PACKAGE: file://C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 - Size mismatch: Ini-file: 73505 != On-disk: 10523
2022/03/10 13:46:18 Downloaded file C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 is corrupt; deleting.
2022/03/10 13:46:18 download error in unattended_mode: 1 retry remaining.
2022/03/10 13:46:20 Downloaded file C:\intelFPGA_pro\20.1\embedded\cygwin_setup/https%3a%2f%2fcygwin.mirrors.hoobly.com%2f/x86_64/release/alternatives/alternatives-1.3.30c-10.tar.bz2 is corrupt; deleting.
2022/03/10 13:46:20 download error in unattended_mode: out of retries
2022/03/10 13:46:20 note: Download incomplete. Check C:\intelFPGA_pro\20.1\embedded\host_tools\cygwin\var\log\setup.log.full for details
2022/03/10 13:46:20 Ending cygwin install
YEan
Have you direct to the correct location with "\" for this command soceds-cygwin-setup.bat %USERPROFILE%\Downloads\setup-x86_64.exe ?
Rainwang
New Contributor II
yes, infact, i copy the setup-x86_64.exe file to the same folder as soceds-cygwin-setup.bat, then run the command as below:
soceds-cygwin-setup.bat setup-x86_64.exe
after i run the command, in fact the most files are downloaded successfully, but at last the error always appears as i prevously send to you.
i attached the setup.log for your reference.
YEan
I think you need to list out the directory of setup-x86_64.exe after the command. I attempt to download cygwin and locate the .exe in my local disks. It ran successfully at the end.
Rainwang
New Contributor II
YEan
I’m glad that your issue has been resolved. I'll now transition this thread to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
