573 Discussions
Using HDMI in HPS of HAN Pilot Board (Arria 10)
DKam0
I'm working on the HPS ( linux BSP) of HAN Pilot board (Arria 10) and am trying to display my image data through HDMI.
From the intel site, I can download the "HAN_v.1.0.5_HWrevE-SystemCD" with some demonstration projects.
There is Demonstration/SoC_FPGA/a10s_hdmi project, but I can't find the C program for that.
About the led example, there is an example C code and a manual.
Can I take a example C code for the HDMI in HPS ?
And which paper should I read for this?
In order to control the HDMI and transfer image data, ​
what should i use as memory mapped address in HPS?
In order to store data in SDRAM,
When I open the Demonstration/SoC-FPGA/a10s_hdmi project in Quartus and open soc_system.qsys in platform designer, a error message " i2c_opencores_hdmi: Component type i2c_opencores is not in the library" show up.
In fact, there is no the IP module about i2c_opencores_hdmi (quartus 18.1 standard, pro, 19.1...)
How can I solve this problem?
AnilErinch_A_Intel
Hi
We don't have a C source code for HDMI example , but there are different references which you can check.
Regarding the different parts of your question
1.Please check the HDMI Display Data Channel (DDC) which is based on I2c
https://www.intel.cn/content/dam/www/programmable/us/en/pdfs/literature/an/an837.pdf
2.Regarding HDMI , please find a reference design on the Helio Board
https://rocketboards.org/foswiki/Projects/HDMIDisplayOutputAlteraVideoAndImageProcessingVIPAndNetworkCameraServer
3.Please see the Terasic resources for Han Pilot board also.
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=228&No=1133&PartNo=4
Also since Han Pilot Board is Arria10 , you can explore the HDMI IP for Arria10
https://www.intel.co.jp/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-hdmi-de.pdf
Thanks and Regards
Anil
