- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Why qse driver init failed on arria10 when use ramfs to startup, while it can successfully boot when use nandroot with same rootfs.
Hello. Have a nice day.
I met a problem with ARRIA10 SOC, please help.
Hardware : Altera SOCFPGA Arria10
model name : ARMv7 Processor rev 1 (v7l)
linux kernel tag: ACDS21.1_REL_GSRD_PR
linux kernel version: 5.4.94
First of all, we use nandroot to startup, write rootfs on nand flash followed the steps described in Arria_10_SoC_45_Boot_from_NAND, the system startup successfully, and the qse driver runs OK.
While we found some running efficiency issues on nandroot , so build the rootfs in the kernel to try ramfs.
operations in uboot such as
1. load the new kernel, tftpboot 0x2100000 kernel.itb
2. setenv bootargs console=ttyS0,115200 rdinit=/sbin/init
3. bootm 0x2100000
but the system startup failed when qse driver init. panic occured at qse_get_stats64.
it seems like qse's mac space ff220000 cannot read/write through axi interface although it already was ioremaped in probe.
if I remove the qse driver when build kernel, system can startup successfully.
I think the ramfs change only influence after driver init, so I can't figure why the qse driver init failed with ramfs startup.
Log is below, please someone help me with this problem!
Starting kernel ...
Deasserting all peripheral resets
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.94 (xiejie@topvision) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #16 SMP PREEMPT Thu Sep 16 10:00:07 CST 2021
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Altera SOCFPGA Arria 10
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 18 pages/cpu s44940 r8192 d20596 u73728
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttyS0,115200 rdinit=/sbin/init
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 492464K/524288K available (6144K kernel code, 302K rwdata, 1252K rodata, 18432K init, 127K bss, 31824K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] ftrace: allocating 21743 entries in 43 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310: enabling full line of zeros but not enabled in Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410030c9, AUX_CTRL 0x76560001
[ 0.000000] random: get_random_bytes called from start_kernel+0x338/0x4e0 with crng_init=0
[ 0.000000] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
[ 0.000005] sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 21474836475ns
[ 0.000014] Switching to timer-based delay loop, resolution 10ns
[ 0.000288] Console: colour dummy device 80x30
[ 0.000319] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=1000000)
[ 0.000331] pid_max: default: 32768 minimum: 301
[ 0.000447] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000457] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001027] CPU: Testing write buffer coherency: ok
[ 0.001067] CPU0: Spectre v2: using BPIALL workaround
[ 0.001309] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001883] Setting up static identity map for 0x100000 - 0x100060
[ 0.002016] rcu: Hierarchical SRCU implementation.
[ 0.002306] smp: Bringing up secondary CPUs ...
[ 0.003005] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.003013] CPU1: Spectre v2: using BPIALL workaround
[ 0.003151] smp: Brought up 1 node, 2 CPUs
[ 0.003161] SMP: Total of 2 processors activated (400.00 BogoMIPS).
[ 0.003168] CPU: All CPU(s) started in SVC mode.
[ 0.003613] devtmpfs: initialized
[ 0.008212] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.008489] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008509] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.009368] NET: Registered protocol family 16
[ 0.010129] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010949] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.010959] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.025389] pps_core: LinuxPPS API ver. 1 registered
[ 0.025401] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.025435] PTP clock support registered
[ 0.025485] FPGA manager framework
[ 0.026290] clocksource: Switched to clocksource timer1
[ 0.062454] NET: Registered protocol family 2
[ 0.063035] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.063059] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.063096] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.063151] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.063244] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.063276] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.063444] NET: Registered protocol family 1
[ 0.063478] PCI: CLS 0 bytes, default 64
[ 1.004112] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 1.008740] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.009272] io scheduler mq-deadline registered
[ 1.009282] io scheduler kyber registered
[ 1.014134] dma-pl330 ffda1000.pdma: Loaded driver for PL330 DMAC-341330
[ 1.014150] dma-pl330 ffda1000.pdma: DBUFF-512x8bytes Num_Chans-8 Num_Peri-32 Num_Events-8
[ 1.017009] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 1.018009] printk: console [ttyS0] disabled
[ 1.018080] ffc02100.serial1: ttyS0 at MMIO 0xffc02100 (irq = 43, base_baud = 6250000) is a 16550A
[ 1.500954] printk: console [ttyS0] enabled
[ 1.506555] brd: module loaded
[ 1.516974] loop: module loaded
[ 1.549055] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xda
[ 1.555385] nand: Macronix MX30LF2G18AC
[ 1.559240] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.567096] Bad block table found at page 131008, version 0x01
[ 1.573133] Bad block table found at page 130944, version 0x01
[ 1.604940] 11 fixed-partitions partitions found on MTD device denali-nand
[ 1.611814] Creating 11 MTD partitions on "denali-nand":
[ 1.617117] 0x000000000000-0x000000100000 : "spl"
[ 1.627064] 0x000000100000-0x0000001c0000 : "uboot"
[ 1.637040] 0x0000001c0000-0x000000280000 : "uboot-update"
[ 1.647011] 0x000000280000-0x0000002a0000 : "env"
[ 1.656996] 0x000000300000-0x000002700000 : "fpga"
[ 1.667010] 0x000002700000-0x000003200000 : "kernel"
[ 1.677018] 0x000003200000-0x000007200000 : "rootfs"
[ 1.687026] 0x000007200000-0x000009600000 : "fpga-update"
[ 1.697026] 0x000009600000-0x00000a100000 : "kernel-update"
[ 1.706990] 0x00000a100000-0x00000e100000 : "rootfs-update"
[ 1.717000] 0x00000e100000-0x000010000000 : "app"
[ 1.729317] altr_a10sr_gpio altr_a10sr_gpio.1.auto: DMA mask not set
[ 1.736508] libphy: Fixed MDIO Bus: probed
[ 1.740856] intel_fpga_qse_ll ff220000.ethernet: DMA RX CSR at 0xff200520
[ 1.747726] intel_fpga_qse_ll ff220000.ethernet: DMA TX CSR at 0xff200420
[ 1.754600] intel_fpga_qse_ll ff220000.ethernet: Defaulting RX Poll Frequency to 128
[ 1.762321] intel_fpga_qse_ll ff220000.ethernet: Defaulting TX Poll Frequency to 128
[ 1.770053] intel_fpga_qse_ll ff220000.ethernet: XVCR Ctrl at 0xff222000
[ 1.776831] intel_fpga_qse_ll ff220000.ethernet: TOD Ctrl at 0xff226000
[ 1.783964] 8<--- cut here ---
[ 1.787009] Unhandled fault: imprecise external abort (0x406) at 0x8b64dc16
[ 1.793937] pgd = (ptrval)
[ 1.796631] [8b64dc16] *pgd=00000000
[ 1.800197] Internal error: : 406 [#1] PREEMPT SMP ARM
[ 1.805312] Modules linked in:
[ 1.808358] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.94 #16
[ 1.814336] Hardware name: Altera SOCFPGA Arria10
[ 1.819028] PC is at qse_get_stats64+0x20/0x1e4
[ 1.823539] LR is at dev_get_stats+0xac/0xc0
[ 1.827789] pc : [<c048ea70>] lr : [<c0503c64>] psr: 60000013
[ 1.834026] sp : df4bfb40 ip : df4bfb58 fp : df4bfb54
[ 1.839225] r10: dc611800 r9 : c1b37a80 r8 : 00000010
[ 1.844424] r7 : dc610800 r6 : dc611900 r5 : dc60c000 r4 : c1b34888
[ 1.850920] r3 : e0928000 r2 : 50c887b5 r1 : dc611900 r0 : dc610800
[ 1.857418] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 1.864520] Control: 10c5387d Table: 0000404a DAC: 00000051
[ 1.870238] Process swapper/0 (pid: 1, stack limit = 0x(ptrval))
[ 1.876216] Stack: (0xdf4bfb40 to 0xdf4c0000)
[ 1.880557] fb40: c1b34888 dc60c000 df4bfb7c df4bfb58 c0503c64 c048ea5c dc6118fc dc60c000
[ 1.888699] fb60: dc610800 c1b06bd0 00000010 c1b37a80 df4bfb9c df4bfb80 c0524420 c0503bc4
[ 1.896840] fb80: dc60c000 dc610800 df4bfbd0 c1b06bd0 df4bfc14 df4bfba0 c05295cc c05243ec
[ 1.904981] fba0: 00000010 00000000 df4bfbdc c024744c dc60c000 c1b05088 c1b37a80 00000000
[ 1.913121] fbc0: c024744c c1b05088 dc60c000 c1b05088 00000000 df4bfbe0 00000000 c04f24b0
[ 1.921262] fbe0: 00523e14 cd61a3fb 00000000 00000000 00000cc0 dc60c000 ffffffff 00000000
[ 1.929402] fc00: c1b37a80 00000010 df4bfc6c df4bfc18 c052b8c8 c052909c 00000000 00000000
[ 1.937542] fc20: ffffffff 00000000 00000000 00000000 00000000 00000000 ffffffff 00000cc0
[ 1.945683] fc40: 00000000 00000cc0 dc610800 00000000 00000000 00000001 dc610d00 dfbf43e0
[ 1.953824] fc60: df4bfc94 df4bfc70 c052b960 c052b830 00000cc0 00000000 00000000 c014967c
[ 1.961965] fc80: dc610800 c1b05088 df4bfcb4 df4bfc98 c052bb04 c052b938 00000cc0 00000000
[ 1.970105] fca0: 00000000 c1b05088 df4bfcf4 df4bfcb8 c0513a90 c052bacc 00000000 dc610d00
[ 1.978246] fcc0: df4bfce4 dc610800 00000000 cd61a3fb dfbf43e0 dc610800 df5aca00 df5aca10
[ 1.986386] fce0: c1b05088 00000000 df4bfd0c df4bfcf8 c0513ac4 c0513548 dc610800 df5aca00
[ 1.994527] fd00: df4bfd64 df4bfd10 c048f5bc c0513aa4 00000000 c07d6840 dc5f6ba0 dc610d08
[ 2.002669] fd20: df59d6c0 df5acc00 df5acce0 df5acc20 df5acd00 cd61a3fb df5aca10 df5aca10
[ 2.010810] fd40: 00000000 c1b34830 00000000 c1b34830 00000000 00000000 df4bfd84 df4bfd68
[ 2.018950] fd60: c042a074 c048f0b0 c1b66aa8 df5aca10 c1b66aac 00000000 df4bfdb4 df4bfd88
[ 2.027091] fd80: c0427a94 c042a028 00000000 df5aca10 c1b34830 c1b34830 c1b05088 ffffe000
[ 2.035231] fda0: c1b4c000 c0944854 df4bfdec df4bfdb8 c0427df0 c04278d0 c04d2954 c06a5798
[ 2.043373] fdc0: df5aca10 c0426e50 df5aca10 00000000 c1b34830 c1b05088 ffffe000 c1b4c000
[ 2.051513] fde0: df4bfe0c df4bfdf0 c0428108 c0427d8c 00000000 c1b34830 df5aca10 c1b05088
[ 2.059653] fe00: df4bfe2c df4bfe10 c04281a0 c04280ac 00000000 c1b34830 c0428110 c1b05088
[ 2.067794] fe20: df4bfe5c df4bfe30 c0425ac8 c042811c df4bfe54 df4aa158 df59c0b4 cd61a3fb
[ 2.075935] fe40: c1b34830 dc5f1b80 c1b30b10 00000000 df4bfe6c df4bfe60 c04272f8 c0425a50
[ 2.084076] fe60: df4bfe94 df4bfe70 c0426ce4 c04272d8 c07e02f4 df4bfe80 c1b34830 c1b46040
[ 2.092218] fe80: c092c1fc 00000000 df4bfeac df4bfe98 c0428e04 c0426b7c c1b30b10 c1b46040
[ 2.100358] fea0: df4bfec4 df4bfeb0 c0429fc4 c0428d84 c1b05088 c1b46040 df4bfed4 df4bfec8
[ 2.108499] fec0: c092c220 c0429f80 df4bff4c df4bfed8 c01032b0 c092c208 00000000 c07b1554
[ 2.116640] fee0: c07b1534 c07b1500 c07c2490 c1b05088 00000000 c07b150c 00000006 00000006
[ 2.124780] ff00: 00000000 c090063c c07e2944 c0838514 df4bff34 dfffce95 dfffce9c cd61a3fb
[ 2.132921] ff20: 00000000 cd61a3fb c1b4c000 c096394c c1b4c000 00000007 c0944834 00000083
[ 2.141061] ff40: df4bff94 df4bff50 c09012ac c0103258 00000006 00000006 00000000 c090063c
[ 2.149202] ff60: c090063c c0838514 c06a5760 00000000 c069f0b8 00000000 00000000 00000000
[ 2.157342] ff80: 00000000 00000000 df4bffac df4bff98 c069f0d0 c09010d0 00000000 c069f0b8
[ 2.165482] ffa0: 00000000 df4bffb0 c01010e8 c069f0c4 00000000 00000000 00000000 00000000
[ 2.173622] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.181761] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 2.189896] Backtrace:
[ 2.192337] [<c048ea50>] (qse_get_stats64) from [<c0503c64>] (dev_get_stats+0xac/0xc0)
[ 2.200216] r5:dc60c000 r4:c1b34888
[ 2.203784] [<c0503bb8>] (dev_get_stats) from [<c0524420>] (rtnl_fill_stats+0x40/0x128)
[ 2.211753] r9:c1b37a80 r8:00000010 r7:c1b06bd0 r6:dc610800 r5:dc60c000 r4:dc6118fc
[ 2.219465] [<c05243e0>] (rtnl_fill_stats) from [<c05295cc>] (rtnl_fill_ifinfo+0x53c/0xe90)
[ 2.227777] r7:c1b06bd0 r6:df4bfbd0 r5:dc610800 r4:dc60c000
[ 2.233415] [<c0529090>] (rtnl_fill_ifinfo) from [<c052b8c8>] (rtmsg_ifinfo_build_skb+0xa4/0x108)
[ 2.242248] r10:00000010 r9:c1b37a80 r8:00000000 r7:ffffffff r6:dc60c000 r5:00000cc0
[ 2.250038] r4:00000000
[ 2.252565] [<c052b824>] (rtmsg_ifinfo_build_skb) from [<c052b960>] (rtmsg_ifinfo_event.part.12+0x34/0x64)
[ 2.262174] r10:dfbf43e0 r9:dc610d00 r8:00000001 r7:00000000 r6:00000000 r5:dc610800
[ 2.269965] r4:00000cc0
[ 2.272491] [<c052b92c>] (rtmsg_ifinfo_event.part.12) from [<c052bb04>] (rtmsg_ifinfo+0x44/0x4c)
[ 2.281234] r5:c1b05088 r4:dc610800
[ 2.284803] [<c052bac0>] (rtmsg_ifinfo) from [<c0513a90>] (register_netdevice+0x554/0x55c)
[ 2.293032] [<c051353c>] (register_netdevice) from [<c0513ac4>] (register_netdev+0x2c/0x44)
[ 2.301345] r8:00000000 r7:c1b05088 r6:df5aca10 r5:df5aca00 r4:dc610800
[ 2.308018] [<c0513a98>] (register_netdev) from [<c048f5bc>] (intel_fpga_qse_ll_probe+0x518/0x790)
[ 2.316934] r5:df5aca00 r4:dc610800
[ 2.320499] [<c048f0a4>] (intel_fpga_qse_ll_probe) from [<c042a074>] (platform_drv_probe+0x58/0xa8)
[ 2.329503] r10:00000000 r9:00000000 r8:c1b34830 r7:00000000 r6:c1b34830 r5:00000000
[ 2.337294] r4:df5aca10
[ 2.339818] [<c042a01c>] (platform_drv_probe) from [<c0427a94>] (really_probe+0x1d0/0x338)
[ 2.348043] r7:00000000 r6:c1b66aac r5:df5aca10 r4:c1b66aa8
[ 2.353678] [<c04278c4>] (really_probe) from [<c0427df0>] (driver_probe_device+0x70/0x190)
[ 2.361905] r10:c0944854 r9:c1b4c000 r8:ffffe000 r7:c1b05088 r6:c1b34830 r5:c1b34830
[ 2.369696] r4:df5aca10 r3:00000000
[ 2.373258] [<c0427d80>] (driver_probe_device) from [<c0428108>] (device_driver_attach+0x68/0x70)
[ 2.382090] r9:c1b4c000 r8:ffffe000 r7:c1b05088 r6:c1b34830 r5:00000000 r4:df5aca10
[ 2.389798] [<c04280a0>] (device_driver_attach) from [<c04281a0>] (__driver_attach+0x90/0xcc)
[ 2.398283] r7:c1b05088 r6:df5aca10 r5:c1b34830 r4:00000000
[ 2.403923] [<c0428110>] (__driver_attach) from [<c0425ac8>] (bus_for_each_dev+0x84/0xc4)
[ 2.412063] r7:c1b05088 r6:c0428110 r5:c1b34830 r4:00000000
[ 2.417698] [<c0425a44>] (bus_for_each_dev) from [<c04272f8>] (driver_attach+0x2c/0x30)
[ 2.425663] r7:00000000 r6:c1b30b10 r5:dc5f1b80 r4:c1b34830
[ 2.431298] [<c04272cc>] (driver_attach) from [<c0426ce4>] (bus_add_driver+0x174/0x1f8)
[ 2.439266] [<c0426b70>] (bus_add_driver) from [<c0428e04>] (driver_register+0x8c/0x124)
[ 2.447319] r7:00000000 r6:c092c1fc r5:c1b46040 r4:c1b34830
[ 2.452955] [<c0428d78>] (driver_register) from [<c0429fc4>] (__platform_driver_register+0x50/0x58)
[ 2.461956] r5:c1b46040 r4:c1b30b10
[ 2.465522] [<c0429f74>] (__platform_driver_register) from [<c092c220>] (intel_fpga_qse_ll_driver_init+0x24/0x28)
[ 2.475734] r5:c1b46040 r4:c1b05088
[ 2.479299] [<c092c1fc>] (intel_fpga_qse_ll_driver_init) from [<c01032b0>] (do_one_initcall+0x64/0x2d0)
[ 2.488656] [<c010324c>] (do_one_initcall) from [<c09012ac>] (kernel_init_freeable+0x1e8/0x284)
[ 2.497314] r8:00000083 r7:c0944834 r6:00000007 r5:c1b4c000 r4:c096394c
[ 2.503988] [<c09010c4>] (kernel_init_freeable) from [<c069f0d0>] (kernel_init+0x18/0x120)
[ 2.512214] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c069f0b8
[ 2.520004] r4:00000000
[ 2.522529] [<c069f0b8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 2.530061] Exception stack(0xdf4bffb0 to 0xdf4bfff8)
[ 2.535090] ffa0: 00000000 00000000 00000000 00000000
[ 2.543230] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.551369] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 2.557951] r5:c069f0b8 r4:00000000
[ 2.561513] Code: e8bd4000 e59035ec e5932770 f57ff04f (e59035ec)
[ 2.567585] ---[ end trace f48cfc66e084b111 ]---
[ 2.572187] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.579814] CPU0: stopping
[ 2.582516] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 5.4.94 #16
[ 2.589876] Hardware name: Altera SOCFPGA Arria10
[ 2.594556] Backtrace:
[ 2.597001] [<c010d7d4>] (dump_backtrace) from [<c010db0c>] (show_stack+0x20/0x24)
[ 2.604536] r7:60000193 r6:c1b42048 r5:00000000 r4:c1b42048
[ 2.610172] [<c010daec>] (show_stack) from [<c069efa0>] (dump_stack+0x8c/0xa0)
[ 2.617365] [<c069ef14>] (dump_stack) from [<c0111bf8>] (handle_IPI+0x448/0x458)
[ 2.624727] r7:00000000 r6:00000004 r5:c1b460a4 r4:c1aa6018
[ 2.630363] [<c01117b0>] (handle_IPI) from [<c0102398>] (gic_handle_irq+0x9c/0xa0)
[ 2.637899] r10:c07b2154 r9:e0803100 r8:c1b01ec8 r7:e0802100 r6:e080210c r5:c1b29150
[ 2.645690] r4:c1b057cc
[ 2.648213] [<c01022fc>] (gic_handle_irq) from [<c0101a8c>] (__irq_svc+0x6c/0xa8)
[ 2.655660] Exception stack(0xc1b01ec8 to 0xc1b01f10)
[ 2.660689] 1ec0: 00000000 0000091c dfbccc34 c011cbc0 00000001 ffffe000
[ 2.668831] 1ee0: c1b050a8 c1b050e4 00000001 c1b45c49 c07b2154 c1b01f24 c1b01f28 c1b01f18
[ 2.676969] 1f00: c0109b30 c0109b34 60000013 ffffffff
[ 2.681999] r9:c1b00000 r8:00000001 r7:c1b01efc r6:ffffffff r5:60000013 r4:c0109b34
[ 2.689713] [<c0109aec>] (arch_cpu_idle) from [<c06a5514>] (default_idle_call+0x30/0x3c)
[ 2.697770] [<c06a54e4>] (default_idle_call) from [<c01575c4>] (do_idle+0xe0/0x144)
[ 2.705393] [<c01574e4>] (do_idle) from [<c015793c>] (cpu_startup_entry+0x28/0x2c)
[ 2.712928] r10:c0944a3c r9:00000001 r8:00000000 r7:c0944a3c r6:c1b4c000 r5:00000002
[ 2.720720] r4:000000ce r3:c1b00000
[ 2.724281] [<c0157914>] (cpu_startup_entry) from [<c069f0b0>] (rest_init+0xdc/0xe4)
[ 2.731991] [<c069efd4>] (rest_init) from [<c0900b68>] (arch_call_rest_init+0x18/0x1c)
[ 2.739869] r5:c1b4c054 r4:c1b05088
[ 2.743432] [<c0900b50>] (arch_call_rest_init) from [<c090108c>] (start_kernel+0x4a8/0x4e0)
[ 2.751747] [<c0900be4>] (start_kernel) from [<00000000>] (0x0)
[ 2.757641] r10:10c5387d r9:414fc091 r8:09ff5000 r7:00000000 r6:10c0387d r5:00000051
[ 2.765432] r4:c0900330
[ 2.767960] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
What is the version of Uboot that you are using?
Are you using EMAC0 or EMAC1? Is the EMAC working in Uboot before the hang in Kernel?
