573 Discussions
Windows GHRD for cycloneVsoc make failed
CAlex
New Contributor II
Hi
Under SOCEDS v20.1 and Quartus Prime lite 22.1std using MSYS2 running make generate_from_tcl failed duel to the QUARTUS_ROOTDIR error, following is the printscreen of the error:
My variable is correct but the makefile overwrite that.
I tried to fix that but found out:
Any solutions please?
Reguards
Alex
aikeu
Hi CAlex,
To run make generate_from_tcl we will need to initiate the nios2_command_shell
Is ~/intelFPGA/22.1std/nios2eds/nios2_command_shell.sh \ working before you run the generate_from_tcl ?
Link before shows the steps in getting the ghrd and compile the ghrd using commands:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10#Cyclone_V_SoC_and_Arria_V_SoC
Aik Eu
aikeu
Hi CAlex,
Aik Eu
aikeu
Hi CAlex,
Any follow up from the previous comments?
Aik Eu
CAlex
New Contributor II
Yes I worked, thank you for your help.
Please do what ever you want to this thread
aikeu
Hi CAlex,
Great to know that the issue has been resolved! I am closing this thread for now.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
Aik Eu
