573 Discussions
alternate to sys/mmap.h if I am not using HPS ?
Yogesh
I understand sys/mmap.h is used to do memory mapped operations(read/ write to memory) while using HPS in linux environment.
But suppose I try to do the same in other designs where I wont be using HPS / in NIOS eclipse environment, the eclipse tool couldnt recognize sys/mann.h file.
So what is the alternative to do the same in eclipse tool? How to map memory of an FPGA in eclipse tool?
regards,
Yogesh
