cyclone5 hps udp server
aiedb
hii
i have the DE1 BOARD based on cyclone 5 HPS
i want to use the HPS part in order to establish UDP communication with my pc
the board will be a udp server and my pc will be a udp client
is there any tutorial or example that can get me started . thanks for help
JingyangTeh_Altera
Hi aiedb
Unfortunately there is no udp server example from Intel.
However I did find an example from the web that could be useful. I did not try out the example and not sure if it is working or not.
https://www.abc.se/~m6695/udp.html
Jingyang, Teh
JingyangTeh_Altera
Hi aiedb
Any update on this case?
Jingyang, Teh
aiedb
hii good morning
i know how to implement udp and even tcp server in linux , but i was wondering if there is full example of udp or TCP server utilizing the hps proccer of the cyclone 5 , a tcp server example can also be very helpful for me , thanks
JingyangTeh_Altera
Hi aiedb
Sorry, unfortunately there is no official example provided by intel for the UDP server and client.
Jingyang, Teh
JingyangTeh_Altera
Hi
Jingyang, Teh
aiedb
hii ypu can close the case thanks
JingyangTeh_Altera
Hi
Since this thread been resolve, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
