573 Discussions
facing issue with loading the EPCS file and SD milage file on DE10 nano board
Ragul
Hi ,
Currently i'm working on DE10-nano board.My requirement is HPS should booted from SDcard and FPGA should booted from EPCS both should happen from at the same time or with delay also .
but wright now i am able to boot the fpga and EPCS with one mode of MSEL [4:0]: 10010 and for SD card image the switch section is MSEL [4:0]: 01010 both are working as induvally selection
now my requirement is to boot both HPS and FPGA at same time or delay time , request to help me what should be setting for the both HPS( SD card image) and FPGA( EPCS) to boot on its own.
can you help me out with what should be my switch configuration when booth FPGA and HPS to be in auto boot.
Thanks & Regards
Ragul V
Ragul
I am eagerly waiting for your response. Please give me the solution as soon as possible.
With regards,
Ragul V.
Farabi
For FPGA image, you need to convert to .rbf to load together with sdcard image.
No need to load FPGA image from EPCS.
link : https://www.rocketboards.org/foswiki/Documentation/CycloneVSoCGSRD
regards,
Farabi
Farabi
Cyclone V SoC build flow:
Farabi
I have provided the answer. I will transfer this case to community now.
If you have new question, please raise new ticket, we will be happy to help.
regards,
Farabi
