573 Discussions
u-boot make failure: SPL image too big
eng6138
When trying to build u-boot/make the preloader, I get the following message:  arm-altera-eabi-ld: SPL image too big
make CROSS_COMPILE=arm-altera-eabi- -C uboot-socfpga spl/u-boot-spl.bin
cd /home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/spl/ && arm-altera-eabi-ld  -T /home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/spl/u-boot-spl.lds --gc-sections -Bstatic arch/arm/cpu/armv7/start.o --start-group arch/arm/cpu/armv7/libarmv7.o arch/arm/cpu/armv7/socfpga/libsocfpga.o arch/arm/lib/libarm.o board/altera/socfpga/libsocfpga.o board/altera/socfpga/sdram/libsocfpga-sdram.o --end-group /home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/spl/arch/arm/lib/eabi_compat.o -L /opt/intelFPGA/18.0/embedded/host_tools/mentor/gnu/arm/baremetal/bin/../lib/gcc/arm-altera-eabi/6.2.0 -lgcc -Map u-boot-spl.map -o u-boot-spl
arch/arm/cpu/armv7/socfpga/libsocfpga.o: In function `sdram_mmr_init_full':
/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/arch/arm/cpu/armv7/socfpga/sdram.c:377: undefined reference to `__stack_start'
/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/arch/arm/cpu/armv7/socfpga/sdram.c:377: undefined reference to `__sdram_stack_start'
arch/arm/cpu/armv7/socfpga/libsocfpga.o: In function `s_init':
/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/arch/arm/cpu/armv7/socfpga/s_init.c:73: undefined reference to `memset'
/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/arch/arm/cpu/armv7/socfpga/s_init.c:92: undefined reference to `__ecc_padding_start'
/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/arch/arm/cpu/armv7/socfpga/s_init.c:92: undefined reference to `__ecc_padding_end'
/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/arch/arm/cpu/armv7/socfpga/sdram.c:1264: undefined reference to `board_init_r'
/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/arch/arm/cpu/armv7/socfpga/sdram.c:1265: undefined reference to `__stack_start'
/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/arch/arm/cpu/armv7/socfpga/sdram.c:1277: undefined reference to `gdata'
make[2]: *** [Makefile:178: /home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/spl/u-boot-spl] Error 1
make[2]: Leaving directory '/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga/spl'
make[1]: *** [Makefile:611: spl/u-boot-spl.bin] Error 2
make[1]: Leaving directory '/home/firmware/Documents/DE1_SoC_demo_ds5/software/spl_bsp/uboot-socfpga'
make: *** [Makefile:187: uboot-socfpga/spl/u-boot-spl.bin] Error 2
Performing the build on a Ubuntu 20.04 virtual machine which has SoC EDS 18.0.0.614 installed.  BSP and HDL was created on Windows 10 build 19041 using the same Quartus and SoC EDS version.  Target board is the Terasic DE1-SoC dev kit.
eng6138
It appears the problem is fixed by doing a "make clean" and running make again.
eng6138
EBERLAZARE_I_Intel
Glad that the issue is now fixed.
Just for your reference, you may refer below for the latest boot method and debug steps:
https://rocketboards.org/foswiki/Documentation/BuildingBootloader
https://rocketboards.org/foswiki/Documentation/SoCEDS
