Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
A problem about the sgx_sign key
pp__monkeyking
A problem about the sgx_sign key:
     we can use sgx sign tool (sgx_sign) to sign a sgx enclave.so to an enclave.signed.so by a asymmetric key:
     E.g "sgx_sign sign -key enclave_private.pem -enclave enclave1.so -out enclave1.signed.so -config config1.xml";
     but,  the asymmetric key must be a 3072 bites's RSA key ???
     Can I use one 2048 bites's RSA key to sign the encalve?
     or, Can I use one ECDSA(curve secp256k1) key to sign the encalve?
Thans you very mach for you replying.
JesusG_Intel
Hello Monkeyking,
The PEM key file must be an RSA 3072-bit key with exponent 3.
Jesus
Intel Customer Support
