Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
A question about .sign.so file
dai_c_
Hello:
      After I use SGX SDK to generate a .sign.so file ,if I know the edl file and the enclave name(app wants to use), It seems like I can generate a mailcious .sign.so file to replace old .sign.so file. I test this in the example of SampleEnclave and change the enclave code to generate the mailcious .sign.so file; After replacing, It output as changed code. So In SGX,how to bind each app to a specific Enclave?  Thank you bery much!
Scott_R_Intel
Hello.
To be able to load an enclave in production mode, it has to be on the Intel whitelist.  And to be whitelisted, there is a formal process including signing a Commercial License Agreement.  In your example, I assume you simply replaced one debug mode enclave with another, in which case, the whitelist isn't used.
Please see the "Overview of Signing and Whitelisting Intel SGX Enclaves" document at the link below for more details on this:
https://software.intel.com/en-us/sgx/resource-library
Regards.
Scott
Scott_R_Intel
Hello.
Regards.
Scott
dai_c_
Thank you very much!
