Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
About custom data in report_data field of sgx_report_body_t
Zhang__Shifa
I'm designing remote attestation. When I look into the ra sample provided by Intel. The quote is generated by the sgx_ra_proc_msg2() (actually a library trusted function sgx_ra_get_msg3_trusted(). It seems that I cannot put custom data into the report_data of the report body in the quote with sgx_ra_proc_msg2(). So I write a new ecall function in the enclave to call sgx_create_report() to generate a report with custom report_data and write the report to the application buffer. And the application call sgx_get_quote() to get the quote of the report just created by sgx_create_report(). Is this the right way to do that? Thanks.
It seems I should also generate the other fields of the message3. Is there any easier way to do that?
Rosłaniec__Piotr
I'm also interested in including custom payload in report_data. Were you able to simplify this process? Any chance you could share some insights?
Miller__Derek
I second this question. It's a basic feature of most attestation protocols to allow the attesting entity to add additional data to the attestation report, and there is no obvious way to do this with SGX.
muon
I am also wondering how this is supposed to be done. The question has also been asked here: https://github.com/intel/sgx-ra-sample/issues/53, on the repository of the sgx-ra-sample, which is the code for the example at https://software.intel.com/content/www/us/en/develop/articles/code-sample-intel-software-guard-extensions-remote-attestation-end-to-end-example.html.
