Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
Can SGX enclaves run at ring 0?
Mazhar_N_
Is it possible to run SGX enclaves at ring 0?
OR
Can we run SGX enclaves using sudo with root privileges?
I gather that SGX enclaves run at ring 3. Suppose I want to run a program inside SGX enclave which will want to access kernel data structures. Is there any way I could achieve this?
Surenthar_S_Intel
Hi Mazhar,
SGX Enclaves currently only allow for Ring 3 code execution. Intel SGX enclave runs in ring 3 only, no kernel mode.
Intel SGX objective is secure the application in ring 3 itself. Applications are not protected from privileged code attacks. Intel® SGX provides a safe place for code and data in the application.
Thanks and Regards,
Surenthar Selvaraj
Surenthar_S_Intel
Hi Mazhar,
Thanks and Regards,
Surenthar Selvaraj
Mazhar_N_
Surenthar Selvaraj. (Intel) wrote:
Hi Mazhar,
Thanks and Regards,
Surenthar Selvaraj
So that means we cannot run a kernel module inside SGX enclaves, right?
Surenthar_S_Intel
Hi Mazhar,
Yes, We cannot run a kernel module inside SGX enclaves.
-Surenthar.
