Intel® Software Guard Extensions (Intel® SGX)
Discussion board focused on hardware-based isolation and memory encryption to provide extended code protection in solutions.
1545 Discussions
Can an enclave directly access outside space with a virtual address?
Sam5
I have two question here.
  1. If the CPU is in enclave mode, it cannot reach a none-EPC page. That's to say, the code in an enclave cannot directly access outside virtual space.
  2. The enclave can see all the virtual space of this process
-Thanks
Surenthar_S_Intel
Hi Sam,
Yes, an enclave can access the complete address space of the process. Otherwise, communication between enclave and non-enclave would not be possible.The code within an enclave can directly write outside memory and directly read outside memory under previous system policy. However, it cannot fetch outside code.
Thanks and Reagrds,
Surenthar Selvaraj
Juan_d_Intel
While running inside an enclave you can access pages outside EPC that belong to the process that created the enclave. That's how you copy data in and out. You cannot jump to continue execution outside enclave boundaries though.
Surenthar_S_Intel
Hi Sam,
Thanks and Reagrds,
Surenthar Selvaraj
Sam5
Thanks for your information...
